Old 11-20-2012, 01:27 AM   #26
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Cooling System Diagnosis
Originally Posted by sjarrett71 View Post
The temp sensor is located in the rear of the head on the passenger side.
Originally Posted by DesertCat View Post
Sender in the head is not the ideal location, I prefer on the intake manifold.
Any chance that the sender & gauge are working correctly? Maybe that area of the head naturally gets hotter before the thermostat opens -- then the circulating coolant brings the temp down to normal.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-20-2012, 10:00 PM   #27
arider278j
Quick question, have you checked the temp flare up again after you changed the rad. It is common for the first opening of t stat to flare as air is released from right below t stat. Also prob what happened is so one did head gaskets and put heads on wrong sides. This is'nt a problem except for sender location. I would try and remove plug,yes i saw you tried already.
arider278j is offline   Reply With Quote
