Old 11-21-2012, 07:15 AM   #26
K20chevy
K20chevy's Avatar
Re: OEM looking fendertriming for 37" tires
Originally Posted by johnnypop View Post
Pie cut the body line at the curves and pinch it back, be sure you coat the inside of the fenders well once all the welding and bodywork is done or else you'll end up with a rotted mess after a few years of wheeling. The brown truck's fenders were done years ago, will fit 37's on a 4" lift with no rubbing, white truck has received the same treatment, both trucks awaiting sets of 37's right now cause money is tight. Looks super factory, basically you push the rear of the fender back to follow right along the inner fender, then the front I did about 2 inches to make it look clean
WOW, that looks amazing! If you wouldn´t know, you couldn´t really tell the difference! And if you say it clears 37" tires with 4" lift, awesome! That is what I need to do with mine! Do you happen to have a few more pics from the side? looking directly at the fender? Thanks!
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104
68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441
K20chevy is offline   Reply With Quote
Old 11-21-2012, 02:49 PM   #27
wilkin250r
wilkin250r's Avatar
Indeed, that thread is fantastic.
And that brown stepside is sexy!
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 11-22-2012, 04:00 AM   #28
K20chevy
K20chevy's Avatar
x2, the brown truck is nice!!! What color brown is this? OEM color or some custom color? any more pics of that truck?
Old 11-22-2012, 01:55 PM   #29
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
See that's what I plan on doing! Any more pictures from the side johnnypop, or some during the surgery?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 11-23-2012, 02:56 AM   #30
johnnypop
I'll need to get some good side photos, I never made a point of photographing the work in progress... The brown is "factory" by the book, but the actual factory color is a little darker and purple-ish.
johnnypop is offline   Reply With Quote
Old 11-23-2012, 03:26 AM   #31
85sierraclassic
85sierraclassic's Avatar
bout mid way down the page ?
http://southern-truck.com/generalmotors.html
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 11-23-2012, 12:18 PM   #32
K20chevy
K20chevy's Avatar
Thanks jonnypop, some side shots would be great! So the brow is a factory color? Cool, never thought they had cool colors like that stock!
Old 12-12-2012, 04:04 AM   #33
K20chevy
K20chevy's Avatar
Any news on the pictures (side shots) johnnypop???
Old 01-04-2013, 07:12 AM   #34
K20chevy
K20chevy's Avatar
No reply at all????
Old 01-04-2013, 12:25 PM   #35
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I'm in for more pictures as well, here's another picture he posted:
And after some super secret detective work... here is another :
Tony
Old 01-05-2013, 08:37 AM   #36
mckustomfab
I know i'm kinda late to the party, but here is what i plan to do to my '91 crewcab. Section the front and rear of the opening to make it wider and also section it up to make it taller. Check the pics to see what I mean!
Hope this is not to late and it helps!
1991 Chevy Crew Cab R3500 to V3500 Conversion Project:
Build Thread
Photo Bucket Pics
You cant fix stupid, and stupid hurt! Rules to live by.
mckustomfab is offline   Reply With Quote
Old 01-05-2013, 11:56 AM   #37
bohmankid
bohmankid's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=550860
Here are a few pics in this thread.
bohmankid is offline   Reply With Quote
Old 01-06-2013, 02:32 PM   #38
K20chevy
K20chevy's Avatar
Cool, thanks for the info!
Old 01-07-2013, 02:06 AM   #39
K20chevy
K20chevy's Avatar
what size are the tires you are running? they look like at least 40´s....
Old 01-07-2013, 03:17 AM   #40
Devillusion
Devillusion's Avatar
Here is what I did to mine.......see thread for more information. Front fender was lengthened front and back 1.5", and up and inch as well if I remember right. Also brought the front section up to the bottom of the rad support, and brought the rear portion up to the bottom of the door so that it looked right when I put the rock sliders in place. Rear quarters were brought up as well and moved rearward to accomodate the flex of the 56" leaves.
http://67-72chevytrucks.com/vboard/s...d.php?t=443538
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 01-07-2013, 07:18 AM   #41
K20chevy
K20chevy's Avatar
looks really nice! But you can´t run inner fenders with that, correct? at least not the stock ones!?
Old 01-08-2013, 04:15 AM   #42
Devillusion
Yes, running stock inner fenders. See thread for pics.
I had to tack weld mine in place due to structure issues on the bolt placement, but with more careful cuts it would not be a huge issue, just time consuming. But I wanted the same thing you do........more clearance and a somewhat factory look. The K5 above in the picture only has a 3-4" lift with 35" tires on 16x8 wheels.
1970 Chevelle
Old 01-08-2013, 05:46 AM   #43
K20chevy
K20chevy's Avatar
did you stretch the inner fenders too? Mine are farely close up top to the stock opening and only "separate" from the outer edge toward the bottom in the front and back.
I guess I´ll just have to tear into it and go step by step. I want to keep my side marker, but on the 73-80 it is easier due to it being upright.
the tough part for me is, 3-4" lift with 37x12.50R17s and long travel suspension. I´d love to be able to turn the wheels lock to lock at full compresion without touching anything. Not even sure if that works with a 37" tire.
I´m also thinking about a wheel with more backspacing to reduce the forward and back motion of the wheel. but I can only go so far on BS because otherwise the tire will hit the (for now leaf pack) upper or lower 4-link bar.
Thanks for your info!
Old 01-08-2013, 10:37 PM   #44
Devillusion
No, all stock. I just made slits in the fender inner structure where they bolt on and bent them upwards a bit. Some light hammer/dolly work on the sheetmetal and wasn't that bad actually. Fenders were alot more stressful and more work.
I think you should be fine....mine has decent travel for a leaf sprung suspension and doesn't even come close on 35's.
Back spacing won't effect your forward and rearward motion....just on the side to side clearance when you turn. A 3-4" back spacing will hit close to the middle of an 8" wheel and should be fine.
1970 Chevelle
Old 01-09-2013, 08:42 AM   #45
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You can find a guide table here: http://coloradok5.com/tirefitmenttable.shtml
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 02-13-2013, 06:59 AM   #46
K20chevy
K20chevy's Avatar
thanks for the info. Once I get the fenders modified, I can see how far I can go up on full bump and determine the ride hight. Then I can match the rear suspension to it.
The wheels will most likely be 17x8.5 with 4.75" BS. With 37x12.50 tires.
thanks, I´ve seen that table before, but you can fit larger tires if you modify the fenders enough. I was running a 4" lift with 35´s and had no rubbing issues even though it states in this table you need to trim the fenders. I guess it also depends on wheel width, back spacing and the tire you are running.
I´m planning on max 4" lift with 37" tires and no rubbing anywhere. I´ll keep you posted if that works out.
Old 02-20-2013, 09:33 AM   #47
K20chevy
K20chevy's Avatar
I hope to have mine on the truck by May. I´ll post pics as soon as I do!
Old 02-20-2013, 04:35 PM   #48
Duster
Duster's Avatar
Mine has 4" inch leafs, 0 rates (ORD), and 1" body pucks (ORD) Gives it 6" of lift with the ride of a 4" spring.
Tires are 36/13.50 bias plys, which measure to almost 37" when fully inflated.
Duster is offline   Reply With Quote
Old 02-20-2013, 04:55 PM   #49
05duramaxhd
here is my old 86 with 4" rough country, daystar front shackles and the fenders trimmed. it had 36x14.5x15 mickey's on 15x12 mickey classic II's.
05duramaxhd is offline   Reply With Quote
Old 02-20-2013, 04:58 PM   #50
05duramaxhd
another shot
