11-18-2012, 08:50 PM | #26 |
Re: whats the best aftermarket hvac kit on the market
V A is what I plan on buying and Scotts Hotrods will get my business, there customer service is next to none, I bought all my static drop from them
11-19-2012, 12:25 AM | #27 |
My Blazer has no A/C, the stock heater blows as good as these trucks will....lol.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
11-19-2012, 12:40 AM | #28 |
Pics of the electric setup?
I have an a/c cab...just want to see the setup Posted via Mobile Device
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
11-19-2012, 02:08 AM | #29 |
I can tell you the best one is not Old Air the unit. although it has been in for 11 years I have replaced the blower motor, repaired a broken wire on another.upgraded to electric switches cause I was tired of pulling the cables from under the hood. It works fair on both heat and cool. I added a vent to blow on the floor for the cold feet in winter. If I was to do it again I would find all the factory componets and build a system that way.
Mark 67 c20 custom camper 55 Olds 2dr hardtop 96 mustang 11 dodge nitro |
11-19-2012, 10:30 AM | #30 |
computer illiterate
So to the guys that have Vintage Air, in your opinion now that heinsights 20/20 is this a major upgrade over stock and well worth the money or would you not do it again? Old air peopele need not reply to this question I have had there product and think its not so great!
72 2wd blazer 72 swb 4x4 |
11-19-2012, 12:14 PM | #31 |
IMO, while I have not charged the unit yet, this is a major upgrade over stock. When I looked at stock replacement parts to get my 40 year old system working (POA valve, condenser, drier, compressor, heater core, blower motor, misc seals, gaskets, muffler, hoses, etc) there was not much difference in cost VS a VA sure fit kit with electronic controls. I have several friends with VA kits and they tell me that they don't run the system on high for very long because it's to cold. I'll know first hand next summer.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
11-19-2012, 01:15 PM | #32 |
Future TOTM Winner
When I bought (back) the 72 swb in my sig it had recently had a vintage air kit installed. It looks good, and in 105* Texas heat had no problem keeping the cab cool. Back in the summer time my vent thermometer said it was blowing at 50*. Not the coldest vent temps I have ever seen but definitely more than is needed for the small cab. I didn't install it so I can't speak to that, but once in the vehicle I am very happy with it. Vintage Air is here in San Antonio and I have visited their facility many times. The production floor is clean and well organized and I feel that shows in the quality of their finished product. I have also had very in depth conversations with a few local A/C repair shops and all speak very highly of Vintage Airs product, but some of the other brands not so much. If I already had an OEM setup in a truck (like I do in my Blazer) I would/will probably keep that setup and have it retro fitted to newer technology just because I tend to lean toward keeping stuff OEM in general. BUT as far as putting air in a vehicle that was originally NON-A/C I would buy Vintage Air in a heart beat, no questions asked. In my opinion much better than the other kits I have seen and much easier than trying to convert over to an OEM system. Just my $0.02.
EDIT: I feel the need to add that when I say I would keep an OEM system if I already had A/C, I need to make it clear that little would be OEM after I got through with it. I would use a newer compressor either a Sanden or Denso (stock LSx compressor) not the Frederick style or whatever it was that came on these trucks. Also I would convert the system from a POA setup to an orifice tube system not to mention a new style cross flow condenser. All the under hood stuff including the lines would be built at an A/C shop. The only real original style parts would be the evaporator core and all the under dash stuff. The main advantage to the OEM under dash unit is it has the ability to pull fresh air or recirculated air, where as the Vintage Air kit is ALWAYS pulling recirculated air. This is fine for A/C use, but running a heater with recirculated air sometimes makes things seem a little stuffy/stale, but maybe that's just me.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 11-19-2012 at 07:16 PM. |
11-19-2012, 06:02 PM | #33 |
Thanks meathead,,
Things happen for a reason! |
11-19-2012, 07:51 PM | #34 |
computer illiterate
I just ordered the Vintage Air dire fit gen 4 kit from Scotts Hotrods here on the board, they recommended using an ac controller so I ordered one of those also so well see how it goes!
11-19-2012, 07:51 PM | #35 |
computer illiterate
Sure not dire lol....
11-19-2012, 08:53 PM | #36 |
I installed the VA surefit system in my 69 c10 this summer,very pleased with the fit of the parts and customer service.If I did it over I would have not ordered the surefit system but assemble a package unit that fit my needs better.I did not use the harness that lets you use the factory heater control,instead I got a rotary swich module and fabed it in the heater control area,gutted the heater control.Also upgraded the vents,used the double vane chrome{round}in the dash and a rectangular in the console.Also used longer lines to route behing fender instead of across wheelwell. |
