Old 01-18-2013, 10:30 AM   #26
Bhelton
Bhelton's Avatar
Re: 6.0 swap
Originally Posted by ls1nova71 View Post
There's a fitting in the back of the intake for power brakes, but most LQ4's came with hydroboost so it will have a plug. You can replace it with the nipple, they're only a couple bucks at the dealer. Also there are vacuum ports on the side of the intake for small hoses. You have to break off the little tab on the end to use them.
Have you got pictures of it? Mines out of a Denali
Bhelton is offline   Reply With Quote
Old 01-18-2013, 12:16 PM   #27
bohmankid
bohmankid's Avatar
Re: 6.0 swap
Originally Posted by yossarian19 View Post
Also make sure your PCM is programmed for the right VSS speed signal for your transmission, the newer engines expect a higher resolution signal.
Since he's using a th350, it actually doesn't matter what pulse the VSS is set to. Am I wrong? Cuz the trans is not electronic, he doesn't need to specify gears or tire size for his PCM either. Just disable the trans codes altogether.
bohmankid is offline   Reply With Quote
Old 01-18-2013, 12:36 PM   #28
ls1nova71
ls1nova71's Avatar
Re: 6.0 swap
Contrary to popular belief, you really do need a VSS for the engine to run right. It will run with out it, but not as well as it should, you can get stalling problems especially when coming to a stop quickly.
Anyway, here are the pics of the power brake fitting.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-18-2013, 12:59 PM   #29
Bhelton
Bhelton's Avatar
Re: 6.0 swap
You have that part number?
Old 01-18-2013, 01:51 PM   #30
bohmankid
bohmankid's Avatar
Re: 6.0 swap
I know you need a VSS, I was saying it doesn't matter if it's, for example, 4000 pulse VSS or 8000 pulse VSS, since its a non electronic trans. It doesn't matter where the speed sensor is located or the number of pulses, just so PCM knows vehicle is in motion. Sorry i wasn't very clear on my statement above.
Old 01-18-2013, 04:48 PM   #31
ls1nova71
ls1nova71's Avatar
Re: 6.0 swap
