Old 02-06-2014, 12:26 PM   #26
codeJbird
codeJbird's Avatar
Re: Tunnel mods for 6L80E or 6L90E?
Originally Posted by eric8 View Post
Did you use motor mount plates that keep the engine in the stock location?
It is close to stock location. I kept the mounts that came with the motor and fitted them to frame.
Bird
codeJbird is offline   Reply With Quote
Old 02-06-2014, 12:27 PM   #27
codeJbird
codeJbird's Avatar
Originally Posted by Hart_Rod View Post
Here are a few pictures of the high hump mod. You can also lookin in my 68 build thread to find more.
This is exactly how i did mine and it fit just the same.
Bird
Old 02-06-2014, 01:02 PM   #28
eric8
Sorry, I'm a little slow. So the low hump is welded in from the factory and you have to cut it out? But the high humps were bolted in? I seem to recall the factory assembly manual showing both humps being bolt in, but I could be mistaken.
So in order to make a factory carpet mat work, I'd need to order carpet for a big block or 4wd model?
eric8 is offline   Reply With Quote
Old 02-06-2014, 01:10 PM   #29
hugger6933
All low humps are made in the floor. All high humps are bolted in. You can mod a low hump to a high one by cutting out the hump and bolting the high one in. Yes the carpet offered is stated low hump or high hump in most places. I hope this helps clear up a bit for you. Jim
hugger6933 is offline   Reply With Quote
Old 02-06-2014, 03:13 PM   #30
eric8
Gotcha...makes sense and sounds like a mod that I could actually handle doing.
