#26 |
Re: Anyone swap their trailing arms?
I bit the bullet and ordered the ones from ECE..... Then also added 6" drop springs, the super trac bar and the shock relocator kit... Hope it's pretty sweet!
Weev- Posted via Mobile Device
Weev- Life's tough...... It's even tougher when your stupid - John Wayne |
#27 |
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#28 |
on my "72 short step project, i took some low miliege ones i had saved , separated them , blasted them , box the front end, welded them solid , along with plug welded where the rivets were, all while they were clamped up . then por-15 them ,and installed energy suspension poly bushings ... i thought about plating them yet i think it will be fine. i got mild 455 buick , 400 turbo with 3.73's with an auburn ... uh , 3" cpp springs , 1" block , ece deluxe track bar...
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
#29 |
^^ very nice!
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 ![]() |
#30 |
![]() Join Date: Sep 2009
Just an FYI, if any of these tubular arms are capped on both ends and don't have weep holes in them you better drill some. They may eventually fill with moisture and freeze and exspand or even split.
#31 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I aggree but will add that they will rust through too. I use to work for a company called Hancor Inc. They manufactured plastic pipe from 3" to 56" in diameter. Every size had its own tooling. We made tooling stands that could be easely rolled around and in the larger stuff we had to build racks to transport it in. some of the large stuff was shared between a couple of plants. Anyway we use to build them out of square and rectangular tubing and would paint it with rustolium paint. After a few years of use we started discovering rust holes in the lower ends of the tubing and this tubing in a lot of cases was 1/4" wall because the dies that it supported wayed well into the thousands of pounds. After cutting some of the rusted tubes off to repair the stands we looked inside them and discovered that the whole inside was rusted. When we built the racks and stands we would always would plug and weld the ends up tight to keep moisture from getting inside. What we in fact were doing was trapping moisture in them. The moisture in the air that would form condensation, witch would in turn cause the rust that eventualy go through the steel. The fix to our problem was to not only drill weep holes in the tube, but we also drill vent holes so air could flow through and dry the condensation up. Once we did that the problem went away. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#32 | |
