12-06-2012, 11:14 PM | #26 |
Re: Wouldn't start. Now starts!!???
Oem fuel pumps are a piece of cake! Its on the passenger side, towards the bottom front if ya didn't know.
Posted via Mobile Device |
12-06-2012, 11:17 PM | #27 |
Thanks 70c10
12-06-2012, 11:19 PM | #28 | ||
"I ain't nobody, dork."
Looks like you have headers, which could help to cause the solenoid heat soak/no start condition. Also the engine is either from a later model vehicle or someone swapped the alternator over to the passenger side. The '67 to '72's all had the alternator on the drivers side. Seeing that you said that the heads are camel humps. There should be no accessory holes in the heads. Unless someone drilled and tapped them. So check your alternator mount to make sure it's stable.
My engine is runnin' 10.5:1 compression and I can run on 89 octane fuel. Unless you have some serious compression, or are spending some time above 5,500 RPM's, you're tossing money away by burning premium fuel. That being said. Run a tank of 87 in it and see if it pings and has no balls. If it does... step up to 89. If it still pings a little, then run 92 in it. My '72 has a TH350 and a SBC 350 that cruises on the Highway at around 3,300 at 70mph. I have 3.73's in the ass end. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
12-06-2012, 11:45 PM | #29 |
Please, please, pleeeeeease do not start replacing parts hoping to get lucky and fix it. It would be cheaper in the long run to hire an experienced mechanic!!!
......its not what your askin', its what your gettin'.... .......every time I screw up, I learn something. Needless to say, I'm learning all the time............ |
12-06-2012, 11:53 PM | #30 |
Not to high-jack the thread, but today when I started the truck, my starter continued to run?? I had to pull a battery cable to get it to stop? It worked normally after that, and has never done that before? what happened?
-Bruton 1968 GMC long bed 5.7/700R4 --I'd rather push a Chevy, than drive a Ford.-- |
12-06-2012, 11:54 PM | #31 |
Come on, Biggestjohn, spending money with no results is fun! Actually, I would only feel good about doing stuff that need to replaced because of age. Battery, fuel pump, starter, etc... Not too expensive and part of the fun is getting to know your way around the truck.
12-07-2012, 12:22 AM | #32 | |
Come on, Biggestjohn, spending money with no results is fun! Yea, been there many times!! My truck prefers to drain my wallet in other ways..........too much imagination is very expensive, and kind of frustrating. If you really want to work on engines/electrical, buy a 1989 Corvette, the one I USED to have taught me a LOT of lessons!!! You will have so much fun fixing it that you will be delirious!!!
......its not what your askin', its what your gettin'.... .......every time I screw up, I learn something. Needless to say, I'm learning all the time............ Last edited by biggestjohn; 12-07-2012 at 12:24 AM. Reason: mo |
12-07-2012, 12:40 AM | #33 |
the starter sounds heat related, my truck had the same symptoms. the exhaust was way too close to the starter, so close i couldnt get my pinky between them. i managed to pull the exhaust away about an inch by loosening the bolts on the down pipe and adjusting it that way. some header wrap might work if you cant move yours.
your backfiring issues could be caused by a lot of different things. start with the simple ones. timing, spark plugs, point gap(unless you have an hei dist ), fuel pressure, carb tune, make sure your coil power wire isnt being tapped into to power anything else. mine was used for three other things and the coil was being starved causing a higher rpm hiccup. check your valve lash, your electrical wires for good connections and general condition (not breaking or corroded), make sure you dont have a vacuum leak or an exhaust leak that could be sucking in cold air. check your spark plug wires as well. none of these check will require you to buy anything unless they happen to be malfunctioning. and if they are why not upgrade
USMC SEMPER FI 68 Chevy Longhorn 350/400 factory posi |
12-07-2012, 12:47 AM | #34 |
check your wires, if they are fine get it bench tested, a lot of places will do it free. maybe your ignition switch got hung up?
12-07-2012, 06:19 AM | #35 | |
HTH, sam |
12-07-2012, 07:33 AM | #36 |
Great suggestions. I will work on it this weekend. Also, going to do a good cleaning of outside and inside. Might polish the paint.
12-07-2012, 08:13 AM | #37 |
just curious when you were driving it did you push the choke off?
I'm just saying that could be your fast idle situation and driving it fast with the choke on could cause the back fireing and cause the engine more heat than normally and then you get the no start If you did push off the choke then I would suspect the starter,battery or cables
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
12-07-2012, 11:59 AM | #38 |
Choke is electronic.
Also, the starter is close to the manifolds. |
