#26 |
![]() ![]() Join Date: Jan 2011
Re: LS Noob question
I have an oportunity to purchase a complete ( but currently apart) 02 model 5.3 with the harness and 160k miles for $400.
I would go through a 60k mile motor if I had one and bore it, general rebuild... so 160k.. is that a major problem? Would this be a good start? Maybe ls2 heads, z06 spec cam, etc. How/ would that all play nicely? Your thoughts? The engine is out of an 02 Silverado. Posted via Mobile Device
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#27 |
LS2 chambers are set up for the LS2's 4.00 inch bore, which won't work on the 5.3's 3.78 inch bore. For a little more money I'd find a complete engine with less miles that hasn't been taken apart. An iron block 5.3 can be bored to 3.90" (LS1 size, 5.7) if you're going to rebuild one.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#28 | |
160k is quite a few miles.
I think you can find a better deal, especially with it benig apart - I paid $500 for my LM7(iron block 5.3) with 80k, all accy's, harness, intake to pan... Per the 1st post, if starting with 5k I'd get an LQ4, 243 heads, MS3 cam, TBSS headers, 4L80, 3200-3500 converter. This won't get the best mileage but it'll run like absolute stink. This way you'll have the 4" bore if you ever want to upgradeto L92 heads. On the cheap, get a 5.3 out of a truck/suburban, make sure to get the pedal, harness and all accy's with it. Have the heads cut, find a used TR224 cam and stick some Comp 918 valve springs in it. Quote:
#29 |
If you're going to stick a cam in it I wouldn't bother with an LS6 cam, there are much better options out there that can use LS3 springs.
Something like a Comp 230/236, small lobe TR224 or an old GM hot cam. |
#30 |
Won't the larger chamber drop the compression ratio?
#31 |
I should have included 799 heads in my statement above, they come on newer 5.3's and some C6's and are identical to LS2/6 heads(243's)
243/799 head chambers are ~3cc larger than 706/862 heads but that's easily overcome by milling them and quite commonly done. Port volume and intake valve sizes are larger on 243/799 heads so they will move powerband up but will also make more peak power than unported 706/862 heads with a good camshaft. |
