#26 | |
The Older Generation
Re: Shift Indicator adjustment
![]() Looks like someone has replaced your stock parts with a Heim joint at that location.... The adjustment instructions in this thread will not work for that. LockDoc
#27 |
You could try to tighten the he in down. If you can't go any further then you can probably cut the threads off some. Let us know how it goes
#28 | |
Thanks for the help. Would this solve my issue or is it something completely different: http://www.speedwaymotors.com/E-Z-Sh...-Kit,1926.html |
#29 | |
LockDoc
#30 |
after browsing YouTube for a few hours I found a video that shows how to adjust the shift indicator spacing using a Lokar Shift Linkage (which I believe is what the PO installed).
Might be helpful if anyone needs in the future: |
#31 |
![]() Join Date: Sep 2013
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
Is it possible that the collar the that the letters are mounted to has moved to the right slightly? Just a thought.
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY! IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE! |
#32 |
#33 |
OK, but the collar itself, have you tried grabbing it with both hands and try to rotate it a little back and forth? It wouldn't need to move much.
