Old 12-18-2012, 11:46 AM   #26
cal30_sniper
cal30_sniper's Avatar
Re: Overdrive Swap Economics
Originally Posted by Ford Assassin View Post
I get 13-14 mpg in town, 18-19 mpg highway in my K5, I have a built 4L80e w/a billet 3600 stall converter and its been hassle free from the word 'Go'.
Keep in mind this with a supercharged engine driven by a guy with a heavy foot.
Details in my sig....
And you've got a significant mpg advantage in nearly every respect. He'll never be able to come even close to that kind of mileage with a 1 ton unless he does a diesel swap. You're using a LS based engine, with all the advantages that go along with that (including computerized engine controls, I assume). It's fine for a light K5, but would be a gas drinking hog in a 1 ton. In fact, that's where almost all of your increased town mpg comes from. That 2wd K5 is literally thousands of pounds lighter than a big block 1 ton truck or 3/4 ton sub.
You've got some real advantages on the highway too. Your 3"/5" drop means that you're pushing much less air. If you lifted it back up to factory height, I bet you'd see about a 2mpg drop right off the bat. You're also running low-profile street tires. If you were running anything close to the factory tire diameter and weight, and you'd lose more mpg. The low profile tires and lightweight truck allows you to run 3.42 gears. He'll never get away with that in a 1 ton with full size tires. More mpg lost. Your 10 bolt rear is also less of a power drain than the gargantuan 14 bolt that he likely has under his truck.
Overdrives make much more sense in small, light cars (which your K5 is bordering on). This is where you see the claims of a 25 or 30% mpg increase. They're not pushing much air, they've got small engines, and their light. The same recipe does not work in a heavy truck. You drop engine RPMs, but the engine has to work much harder to produce enough torque to keep that weight rolling at the lower RPMs. That's why you don't see much mileage on the highway. You'll never see good mileage with a big inch motor in a heavy truck around town. The overdrive has no impact on mileage at all below 45-50 mph.
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress
73 Formula - 400/Doug Nash 4+1, resto on hold
86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale
01 Ram 2500 - 5.9L Magnum, daily driver
91 BMW 325i - Chumpcar series racecar
cal30_sniper is offline   Reply With Quote
Old 12-18-2012, 12:05 PM   #27
cal30_sniper
Another aspect of the TH700 to keep in mind is its extremely deep first gear, and corresponding really long 1-2 shift. Everybody talks about it like its some sort of performance plus to have that really low gear. Other than rock crawling or towing an extremely heavy trailer (which you really won't be doing with a TH700 anyway), it's more of a nuisance than anything. The 1-2 drop really lugs the motor, it was much smoother driving the TH400 around town than the TH700. The 4L80e doesn't have that problem, but it also costs much more, has no provision for a mechanical speedometer, and requires a very expensive dedicated electronic controller unless you're running an LS motor PCM. I'm sure the controllers are reliable, but someday one is bound to give out. If you happen to be that unlucky person, you won't be able to diagnose the problem, nor will you be able to walk into an O'Reilly's wherever you're stranded and order a replacement. Your vehicle will be down for quite a while, not good if you use it as a DD or for a lot of road trips.
For the money spent, you'd be much better building a bulletproof TH700 (~2k) or putting a gear vendors on your TH400 (<1.5k if you watch for a while and find a good deal used). Why spend 2-4k on a good 4L80 setup when a comparable transmission can be had for less money without all the electronic controllers? If you want the best of both worlds, build a TH200. You'll have the lockup converter and overdrive of the TH700, with the gear spacing of a TH400.
Old 12-18-2012, 12:06 PM   #28
Ford Assassin
Ford Assassin's Avatar
I never claimed it was an apples to apples comparo. He asked, I answered.
My tire diameter (275/40/20 or 28.8") is actually about an inch taller than factory tires (225/75/15). Also my 20x8.5" & 20x10" wheels weigh alot more than factory 15x7" steelies.
I didn't choose the 3.42 gears, in fact I am going with either 3.90 or 4.11 gears (along with a custom 9.5" 14 bolt) in the next few weeks.
Mine isn't a daily driver anymore, I just like the OD so I am not spinning the engine to the moon when cruising down the highway.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 12-18-2012, 12:26 PM   #29
cal30_sniper
I gotcha. That's still really sweet mileage out of your setup, I'm just warning that it's in no way applicable to what kind of mileage increase he would get out of a 1 ton big block with an overdrive swap.
I didn't realize that the K5s came with that small of a tire from the factory. That's only a shade bigger than the 275/40/18s that I'm running on my GTA. The 3/4 ton and 1 tons came factory with a 235/85/16 tire (which works out about 32-33" IIRC). They also sit about 2" higher than the factory 1/2 tons, so probably about 5-7" taller than your K5 is now.
Cool setup, but like I said, it has a lot more in common with a car than a big truck when it comes to merits of an overdrive swap.
Old 12-18-2012, 12:33 PM   #30
Firebirdjones
I'm thinking everyones situation calls for a different approach. The 700 works for you, but that's not a trans I want in my tow rig. With a combined 15-16,000 lbs. to pull around I don't trust that trans, not to mention that 1-2 gear spread is absolutely horrible, I couldn't stand leaving red lights with that setup yanking all that weight.
However I recently built a 4L60E to put behind a 6.0 in my blazer, to hold 600HP and quickly spent $1500 on the trans alone. So they aren't exactly an economical swap either. Works fine in my blazer, but I still wouldn't use it in my 1 ton truck.
The 502 in my 1 ton dyno'd at 540 ft lbs. with a very flat 500 ft lbs. curve from about 2600 to 4700 rpms. So it yanks the trailer around even at low rpms very easily, even with the overdrive engaged isn't a problem, which is why I went with Gear Vendor, can't tow in overdrive with a dedicated 4 speed auto overdrive.
I also specifically did the Gear Vendor on the back of the original 400 turbo because I didn't want a lockup converter with this setup. I hate towing with a lockup converter, they constantly kick in and out and drive me nuts even when pulling in 3rd gear. I pull too much weight to deal with that. With the gear splitting ability it's also now a close ratio, it acts like the allison trans in my neighbors duramax. The 400 is still one of the toughest trouble free transmissions that GM built, and the Gear vendor is good for 1500 HP, it's a tough combo that won't break. Just alot of reasons for me that make this combo perfect for the intended use of my truck.
Reliability isn't a really big issue with the electronic stuff. The electric motors on the fans can be bought most anywhere (that's why I use GM stuff ) The electronic transmissions have been around long enough that most all the bugs are worked out. There really isn't anything on my vehicles that I can't repair with relative ease on the side of the road.
I agree, I love simplicity, some of my cars still run points and I'm fine with that. But when you want gas mileage and efficiency, sometimes that simplicity will have to be put asside for some modern tricks. Just how far you want to take it is the question. Lots of mileage can be found other ways before that overdrive goes in.
Firebirdjones is offline   Reply With Quote
Old 12-18-2012, 12:53 PM   #31
cal30_sniper
Well put, and great points. The TH400 and Gear Vendors is by far the best choice for someone who tows heavy stuff. That's why I said that a TH700 or Gear Vendors TH400 would probably be his best choice. Depends on the application to choose between the two. Ditto on the 502, you've got quite a bit more low RPM grunt to pull that overdrive. A 489 (or bored out 496) with the extra stroke would probably be even better for towing and pulling a low overdrive gear. If you run a lot more time unloaded, a 454 (or even a 383, 6.0, etc) will do just fine.
In defense of the overdrive trans though, you can actually tow in overdrive as long as it's built to handle it. Raptor transmissions and PerformaBuilt both offer TH700s that will tow in overdrive all day long for around $2k. I'm sure there are comparable 4L80s that can be bought as well. I see absolutely no reason to go with a 4L60 swap into an old truck. You get virtually no benefit over a TH700, with all of the same hassles involved in the 4L80 swap.
I'm not certain what you're using to control your lock-up converter, but I've never had a problem towing with mine. Hauling 6-8k pounds, I just leave it in direct drive and set the controller to engage the lock-up converter at 60mph. I just leave it on after that, and it will disengage if I drop below 55mph. I've never had to manually disengage it while driving down the highway because I needed more power. I get about 10mpg driving 65-70 with that weight, and trans temp never gets over 180, even in Texas summers. It's actually really nice, because with a lock-up converter, you can run a higher stall to get things moving from a stop, and still get great mileage and low temperatures at highway speeds (no slipping). That higher stall converter makes the 1-2 drop a lot nicer, especially when you're towing. Granted, hauling 16k pounds is probably a whole different story, but most of us really aren't going to be doing that. If that's the case, you're almost certainly better off with a TH400/GV.
Whichever you go with, I think the 4L80e isn't a good choice unless you're also swapping over a LS-style motor and PCM. It's too expensive, and brings nothing to the table that a well built TH700 or TH400/GV setup doesn't do simpler and cheaper.
Old 12-18-2012, 01:31 PM   #32
SCOTI
SCOTI's Avatar
You have more info on your GV swap? I'm curious about the info I read concerning what happened to Bret V from Ride Tech & his camaro.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-18-2012, 01:32 PM   #33
Firebirdjones
These 2 quotes bring up a great issue that I'm sort of on both sides of the fence.
I did the 4L60E in my 4x4 blazer because I like the tunability with a laptop. I already have the software to tune our LS based camaros so that helped with the decision too. Playing with shift points, pressures, lockup, downshifts, is as easy as a few key strokes.
Since the original 350 turbo was slipping, and I knew I wanted an overdrive at that point (it's my daily driver) I had to make a decision.
Much like you are saying,,,,I couldn't see spending $600 or more for a stand alone trans controller when I could run a GM computer that would control an engine AND a transmission. See where this is going? I didn't want a cable operated 700 with a governor. Tuning the governors on the 400turbo cars for precise shift points around here was already time consuming and messy.
So I decided to just do a 6.0 LS swap, 4L60E, and use a GM computer to run the whole mess. In the end it's the best thing I've done to the blazer, knocks down 17 mpg city and 22 mpg highway with 33" tires and 3.73 gears.
It works great in this combo, it's just a driver though.
Old 12-18-2012, 01:34 PM   #34
Firebirdjones
What happened to Bret V from Ride and Tech? Never heard of them.
Old 12-18-2012, 01:58 PM   #35
SCOTI
SCOTI's Avatar
http://www.ridetech.com/48hourcamaro/
I receive the e-mail updates from RideTech & recall they had a failure that Bret contributed to 'owner error'. That might be acceptable for a guy that owns his own company, but not so much for a poor-boy like me.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-18-2012, 02:35 PM   #36
Firebirdjones
I flipped through the links but can't find any mention of the gear vendor failure. Beats me.
Old 12-18-2012, 02:36 PM   #37
Chevyman350
Cost to swap an 80 in to a square is all about how much shoping you want to do, and how crazy you want to go on beefing it up beyond stock (an 80 is stout already) and I am sure some will queston this statement, for most an 80 will not need to be "built" but the rarely found art of transmission tuning will be needed to get the best performance.
I picked up an optishift controller and harness on group buy for 600.00 ish (controller 500 normally 600)
I also picked up an 2003 80 for $250.00 from craigslist.
So I have 850 in my swap
But I am going cummins so I have other costs that I am not showing.
A lower cost controller might be a megasquirt (mega trans) controller.
Chevyman350 is offline   Reply With Quote
Old 12-18-2012, 02:40 PM   #38
Ford Assassin
They are stout bone stock, but they always benefit the roller clutch being replaced by a 34 element sprag (if not already equiped) and a Trans-Go HD2 shift kit.
Cable
Old 12-18-2012, 02:44 PM   #39
Firebirdjones
The amount of mileage comes into play (with me anyway) That's dirt cheap for a 4L80. I had a 2004 model 4L80 with 80,000 miles and even with that low of mileage I didn't want to stick it in my truck without a refresh. Still had to pay $800 for it. Brand new engine with a used trans just isn't a combo I want to run.
So the cost of the rebuild for the trans on top of the purchase price starts to look ugly. Plus I wanted to modify it to tow in overdrive, but had shops telling me they could but don't recommend it, warranties came into play etc....
So I decided to sell it to someone else that didn't mind dropping a used transmission in his vehicle.
Old 12-18-2012, 02:44 PM   #40
Firebirdjones
They are stout bone stock, but they always benefit the roller clutch being replaced by a 34 element spag and a Trans-Go HD2 shift kit.
The later model 4L80's already come with the 34 element sprag....my 04 model had it.
Old 12-18-2012, 02:52 PM   #41
Ford Assassin
No offense dude, but you overpaid for something you were going to tear into anyway. You could of been more patient and found a burnt up core for $200-300. I ended up buying my core from the trans shop for $200.
Not sure who builds your trans, but my guy told me to tow whatever I wanted (as long as I had an external trans cooler). Still has a 2 year unlimited mileage warranty too.
Cable
Old 12-18-2012, 03:20 PM   #42
SCOTI
SCOTI's Avatar
It was in the e-mails updates I was getting once the car was done. It ended their trip on the Power Tour & required replacement (from what I remember). I delete the e-mails on my work account after a certain amount of time when they're from outside sources.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-18-2012, 03:21 PM   #43
Firebirdjones
Not really. Bought the whole mess (6.0 and 4L80E) from a wrecked 2004 3/4 ton for $2k with 80,000 miles. That's about as cheap as they get out here. They broke it down as $1200 for the engine and $800 for the trans, but you can break it down any way that makes you happy
turned out I couldn't use the 4L80 in my blazer swap so I went 4L60 instead, and wanted to use the 80 in my 1 ton for towing. But I'm just not going to drop a used trans in my 1 ton (or any of my vehicles for that matter) so a rebuild is a must for my intended purposes. I don't really care if some shop says stick it in and go with it,,,,they aren't the ones doing the back breaking labor,,,,or coming to get me when I'm stuck 1500 miles away on the side of the road
Old 12-18-2012, 09:51 PM   #44
Ford Assassin
You should of told them to keep the trans and bought the 6.0 LQ4 for $1200 and found a 4L80e core elsewhere.
I think you might of misunderstood earlier about my 4L80e, I bought a '02 core from a trans shop AND had them rebuild it with all the good stuff. Because they rebuilt it and stand behind their work, it has a 2-year unlimited mileage warranty, including towing. I doubt the same warranty would apply with a 4L60e since they aren't known to handle towing duties, regardless of mods. I have been doing business with this shop for 10+ years, they even warrantied a 4L60e with a sheared off input shaft, including the R&R, even though they didn't do the installation.
Lastly, I think you might want to pick another hobby since ALL toy cars/truck breakdown from time to time, regardless of the quality of parts.
Cable
Old 12-18-2012, 09:57 PM   #45
Chevyman350
I aggree but not "nessary"
Old 12-18-2012, 10:01 PM   #46
Chevyman350
You are assuming that I am going to build it. And $250 for the trans i got with converter HIGH???
There is alot of nay sayers on the strength of the 80 I am going to find out for myself, and i can think of no greater test than a cummins.
Sorry wrong quote (oops)
Old 12-18-2012, 10:04 PM   #47
Chevyman350
If you smoke it (un-likely) you still have a good core.
As far as strength / duriability / all I have to say is they came stock behind d-max in the Chevy and GMC fullsize vans (de-rated of course).
And not wanting to put a uesd trans in is a prefrence I can respect. But at 80 k I wouldnt worry much but that is me.
I can agree that there arn't alot of trans shops selling "hot" 80's mostly due to the massive backing of the 700 / 60's and peoples ability to destroy that trans. (heavy truck, high torque, big tires) = alot of repeat buisness.
Old 12-18-2012, 11:39 PM   #48
Firebirdjones
Actually I wanted the 80 for the swap, but it just wasn't going to work in my application after digging into it. No worries though, I sold it for $800 to someone that didn't mind using it as is and then paid me to install it, so it's not like I'm out anything.
I do this for a living so it's too late for me to pick another hobby, I'm in too deep
Old 12-18-2012, 11:45 PM   #49
Firebirdjones
I just don't build my stuff that way. Especially this blazer. The intention was to build it for my daily driver, which it has been for 3 years with this swap now. I wanted something I could turn key and not worry for the next 150,000 miles or more. We take vacations in it, drive 1500 miles from home in it, and serves as the family SUV everyday.
I didn't want to go through the trouble (and money) for this swap to toss in used equipment with nearly 100,000 miles on it, that's about 8 years of driving knocked off the end result for me.
Now if I were installing this stuff just to flip it, or per customer request, that's a different story.
Old 12-19-2012, 04:58 AM   #50
Rogier
Same thing here: I bought the Optishift for 600, trans is a 4L80E HD 4x4 that was recently rebuilt for 450 and some small items totalled to about 1200 for the whole deal.
I've spent so much more on trashing 700's that were advertized to be able to handle 1000HP etc. I've not been able to buy a 700 that handles my modest 400HP engine in the mountains with 6 guys and a loaded truck. After multiple broken 'custom' 700's I gave up. This 4L80E has not let me down thus far and has improved my economy to about 14mpg coming from 11.
Rogier is offline   Reply With Quote
