Old 02-16-2013, 03:54 PM   #26
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Exhaust recommendations? 305 K10
Originally Posted by cam-camaro View Post
I thought they ran off a vacumn, possibly to the canister in the engine compartment. There is a line( VAC I'm assuming) that runs from the front differential to right above the canister, but it plugged off ( and always has been, even when the 4x4 previously worked). Maybe I'm missing a wire connection somewhere for the Auto-hubs. Any Ideas? The 4x4 worked before I rebuilt the motor, so I'm sure something is unplugged somewhere. The truck will still pull through the differential the hubs just won't lock.
That line is a vent, for it
I'd check if the hubs are actually locking
Did you do work on the hubs
They can even loosen up /gap/ cap looks pops out, can push it in by hand?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-16-2013, 08:18 PM   #27
cam-camaro
No they're pretty solid no give when I try to push on them. Their automatic hubs, is there a wire connection for them anywhere?
And how would I test the hubs out to see if their still good?
cam-camaro is offline   Reply With Quote
Old 02-16-2013, 09:30 PM   #28
motornut
78K & 79C Jimmys
motornut's Avatar
Any time I've had to replaced a broken one , its been full of chunks
I've had had auto and manual hubs stolen right off the truck
And noticed some appear now not to need a C clip /snap ring thing
Have you had them apart / repacked
John
Old 02-16-2013, 10:45 PM   #29
cam-camaro
No I haven't, I've never had to mess with hubs before and I wanted to get some advice before I went off venturing into unknown territory.
Old 03-05-2013, 03:26 AM   #30
cmax87v3500
cmax87v3500's Avatar
single 3 inch with your choice of muffler
1987 GMC V3500 Sierra Classic
cmax87v3500 is offline   Reply With Quote
Old 03-05-2013, 06:37 AM   #31
piecesparts
Parts and more parts
piecesparts's Avatar
Everyone for their own, but when I built my 383 stroker engine, I wanted to do it right (so to speak), I talked to a flowmaster tech rep and from his input, I built my exhaust system and it has worked out great. First of all, figure what you want to do for driving, most of mine would be highway with some city involved. From that he told me that I should keep the size of the pipes so that they helped and not hindered the exhaust process. For my engine and my driving 3" exhaust was to large, so we went with a 2 1/" size on the pipes. I am running long tube headers with 3" collectors necked down to dual 2 1/2" pipes/with an "H" pipe at the rear of the tranny. From there I am running two pipes to what used to be Flowmaster mufflers (Now they are stainless steel Magnaflow mufflers) and then over the axle back to two exhaust pipes out the rear of the truck.
This allows the exhaust to NOT become lazy, which would hinder the exhaust flow by causing turbulence in the pipes. It is the cooling of the exhaust that helps to pull the exhaust gasses out of the cylinders and the cooling creates a slight vacuum in that process.
If you use headers, be sure to put the header bolts into the head with teflon tape on the bolts. This trick will keep thebolts tight and you won't have to keep tightening them as you drive. It will also make taking them back out easy, too.
Frank
piecesparts is offline   Reply With Quote
Old 03-05-2013, 02:13 PM   #32
Duster
Duster's Avatar
I am offended that it took 16 posts before anyone go the "Black Sheep" reference...
Row-adds... Rooooooaidds.
Duster is offline   Reply With Quote
Old 03-05-2013, 03:25 PM   #33
99monte
Heres a picture of the truck. By the way, I want to refrain from starting a new thread so hopefully you guys can help me. There is slight knocking/ticking sound coming from the engine bay and underneath the truck. I highly doubt it's a rod bearing( I replaced them ). The truck is a 1986 K10 305.
I'm thinking it may be a knock sensor( I don't know if this truck is suppose to have one or not)
Valve leash( I set it before I started the motor after the rebuilt, and it doesn't sound like a lifter, but then again, I'm an amateur).
Or possibly a loose bolt on the flywheel or flexplate.
Any ideas on how to diagnose this sound?
Put a stethoscope on the mechanical fuel pump,a worn out pump sounds alot like a lifter noise.Pump pivot wears out eventually the pump won't have enough stroke to provide fuel.
99monte is offline   Reply With Quote
Old 03-07-2013, 10:24 PM   #34
Nouseforaname
Thanks I appreciate the advice! I'll be sure to do that. On another note, do you happen to know where the vacumn hose for the 4x4 hubs goes? It's automatic hubs so I know they run off a vacumn, I'm just not sure where. The 4x4 differentials work, the hubs just won't lock. I'm 90% sure it's a vacumn hose I left off when I rebuilt the motor I just don't know where.
Auto hubs are not controlled by vacuum or electricity, they engauge when the front axles are turned.
You can test them by turning the front drive shaft by hand.
They also disengauge and re engage when you change directions(as when your stuck and trying to get out), thats what usually kills them.
Don't pack the auto hub itself with grease as this will prevent them from engauging.
Nouseforaname is offline   Reply With Quote
Old 03-07-2013, 11:47 PM   #35
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
The original poster hasn't posted for three weeks. We went from exhaust to an exhaust leak to talking about hubs. I'm not even sure if there is a question any more?
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
