Old 01-06-2013, 10:22 PM   #26
gumbys10
Re: 22" wheels on burbs Q
I also had to change the panhard bar to a adjustable one to center the diff, on anglr approaches it still rubs, but straight bumps and driving was ok. I am gonna widen my inner tubs to fix this problem.
gumbys10 is offline   Reply With Quote
Old 01-07-2013, 08:10 PM   #27
Aarons72
Aarons72's Avatar
Whats your wheel and tire size? and backspace?
Aaron Anderson
*1971 GMC Burban - Daily
*1962 Nova
Aarons72 is offline   Reply With Quote
Old 01-07-2013, 10:48 PM   #28
gumbys10
Okay the wheels are 20x8.5 front with 4.5 backspacing,rear 20x10 with 5.5 backspacing.
The front tires are 255 /35 20 I think and rear are 315/35/20.
Old 01-20-2013, 09:24 AM   #29
502ms
502ms's Avatar
Could you not roll your front fenders...pull them out some?
I am running an 8" wide wheel with 4.25 backspacing, and I do not rub....and have enough room even when I am all the way down . So you can run the wheels you want...its all about the offset/backspacing and width.
...for a static drop, that is spot on....I would hate for you to lift it up
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 01-21-2013, 03:31 PM   #30
Aarons72
Aarons72's Avatar
I know right! Well, Im trying to run stock inner fenders....right now where I sit I have one inch from the top of my tire to the inner fender. So unless I cut my fenders and do a lot of fabricaton which Im not really capable of...I don't see them fitting. I'm looking into other inner fender options but I dont want to have to change my hood hinges too...This isnt a show car or custom rod...It's just my daily driver.
Aaron Anderson
*1962 Nova
Old 01-21-2013, 03:36 PM   #31
5150
C10 Club Tennessee
5150's Avatar
Check with 67cheby. He has some different inner fenders that will work.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 01-21-2013, 03:37 PM   #32
5150
C10 Club Tennessee
5150's Avatar
Here you go:
http://67-72chevytrucks.com/vboard/s...d.php?t=486039
Bryan
www.gmtruckshow.com
Old 01-21-2013, 04:00 PM   #33
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I am having the same problem with my 20x10's rubbing in the rear when turning. I bought them off craigslist and I think the backspacing is off a little bit.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 01-21-2013, 08:13 PM   #34
Aarons72
Aarons72's Avatar
Ya! I drool all over slosh tubz posts all the time...like i said tho I want to keep this fairly simple and very cheap so the tubs are out of my price range and also relocating the hinges
Aaron Anderson
*1962 Nova
Old 01-21-2013, 08:16 PM   #35
Aarons72
Aarons72's Avatar
Ill let you know if this spacer and wierd lugnut thing I have coming works out. I'm not exactly sure what is on its way but the shop I bought my wheels from is sending me some spacers and some sort of lug nut that he said is specially designed for using with spacers...it is supposed to give you more thread useage etc...Not sure what to expect. Anyway...it looks like we'll need to mini tb, go with a wider rear end, throw in some spacers or make some suspension upgrades.
Aaron Anderson
*1962 Nova
Old 02-03-2013, 06:24 PM   #36
502ms
502ms's Avatar
Glad you found a solution.
Best Regards,
Leon M.
