#26 |
Re: Air bag installation
Oh, yeah, I also have the adjustable trac bar, lol. Few more pics
=MATTHEW 69 Stepper...Stroked & Bagged ![]() 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
#27 |
C/10 junkie
Loos good cubber. What brand of trailing arms are those?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#28 |
I got them from Classic Parts. They were like $50 more than a set of the stock type. I had a 72, and the arms on it were rusted through. Before I sold it, I swapped the trailing arms (and all the other good 5 lug, disc brake,power steering type pieces,lol).
#29 |
C/10 junkie
Good deal. Sounds like you got all the good stuff
![]() Posted via Mobile Device
#30 |
Yeah. I will be following your decision, and I have noticed that you are a lot of help to lots of people on here. If you have any questions about e products or install, feel free to pm me, because I would be honored to help you in any way I could.
#31 |
your front is super easy to bag. do you have speindles already? can you weld/cut steel? i can walk you through step by step. it really only costs about 250 dollars to bag the front of a chevy. (air bags are around 89 dollars each)
of course this is no compresser/valves, just bags and gettin them in there, making your truck go up and down. |
#32 | ||
C/10 junkie
H
#33 |
![]() ![]() i use no cups, i trim the upper spring mount up about an inch, and then a 2.5 pipe in the bttom control arm. i cna get you some better pics, but it might take an extra day being im in afghan, and truck is in phx.. |
#34 |
C/10 junkie
If you could post more pics that would be great. No rush as I won't be bagging it for a few months.
#35 |
He's right, it would be super easy to make your own stuff, especially for a "certified welder", lol. All you would really need is your bags and some plating, and a piece of pipe. You just have to decide how much you are willing to cut and modify your stock pieces. I could unbolt my upper plates, pull the bags and go back with stock springs if I wanted, but mine won't go as low as some. If you can come up with a set of a arms (lower) you could cut them, and install your pipe, and just swap out when you're ready. I just didn't want to cut mine because I didn't know if I would like the bags or not, but the lower bag cups that come with the PB kit are pretty low, lower than some of the ones that people have to cut down.
#36 |
C/10 junkie
Will the front crossmember sit on the ground aired out with no bump stops and the PB lower bag cups installed?
#37 |
Depending on the OD of the front tire & if it has dropped spindles, yep.....
#38 |
C/10 junkie
I have dropped spindles and will be running P215/70R15 tires.
#39 |
![]() ![]() Join Date: Jan 2011
Lay it out!
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#40 |
C/10 junkie
#41 |
That's 26.85" tall for front rollers & should put the a-arm bushing pivot points on the dirt.
#42 | |
C/10 junkie
#43 |
Kill Bill...et
Thats the same size tire I'm running on my '67 with McGaughy's drop spindles and you can see where the arms are hitting the deck here. You wouldn't be able to fit a cigarette under the crossmember here either. Plus, the tires hit the inner fender wells about the same time.
#44 |
C/10 junkie
Looks great Steve, any more pics of your truck and or install?
#45 |
Kill Bill...et
It's not too pretty, but it's a driver, and I built it myself....and after seeing these, I see my photography skills are about as good as my truck building skills.....LACKING.
#46 |
C/10 junkie
I see no problems with your build, looks great to me
#47 |
Shawno, these guys are tellin' the truth. My Contol arms are stock, I have 2.5" McGaughy spindles and a 29" tall tire. If I had a similar size, my bushings would be real close. HMMM, I think I have a set of 215's, with skinny whitewalls on the carhat the engine blew in on my way home from SoKY Classics tonight.
Steve, I really like your truck, brother!
#48 |
http://67-72chevytrucks.com/vboard/s...d.php?t=335590
here is a thread from when i bagged my truck, most parts were picked up from craigslist after studing the info from here.
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black ![]() Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
#49 |
C/10 junkie
Thanks firedog. There is some useful tips I will be using.
#50 |
