Old 12-30-2012, 02:26 PM   #26
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: A/C cab ?
The vintage air unit I put in my 72 Camaro, the heat never worked like the factory unit. I wouldn't use one again if I ever built another Camaro.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-30-2012, 02:28 PM   #27
Dieselwrencher
Re: A/C cab ?
[QUOTE=AusTx68;5784633]I added a Vintage Air system to my non AC cab. My firewall is smooth so I couldn't go with the out-of-the-box setup.
Personally I would avoid a stock AC setup. That technology is 40+ years old. The new aftermarket systems are highly efficient and do a great job. [QUOTE]
There's nothing wrong with a stock a/c system. They worked great back then and will again. Sealing up the cab is more of the issue. And many people do not properly charge a retro'd 134 system.
Ryan
Old 12-30-2012, 04:02 PM   #28
Graham57a
Graham57a's Avatar
Re: A/C cab ?
[QUOTE=Andy4639;5781307][B][COLOR="Red"]Graham57a,
See if this works. You will need the AC when we head out in June for the Power Tour. Texas will be a little warmer than here I would think.[ The humidity should help a lot though.
I wish I was going to have AC, but if I'm taking Jane I will barely have the funds to get the paint and wheels. I'll just roll my window down and drive fast!!!
Graham57a is offline   Reply With Quote
Old 12-30-2012, 04:54 PM   #29
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Re: A/C cab ?
Interesting. I've installed two VA kits in non-air cabs. One, the 72, and the other, the current 68.
In both installs, the heater (and defrost) would/will cook me outta there if I don't turn it down.
Of course, it doesn't get much below 20 degrees F in the winter here.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 12-30-2012, 06:18 PM   #30
AusTx68
AusTx68's Avatar
Re: A/C cab ?
I think that depends on where you live. Here is Texas I have heard plenty complaints about the performance of a stock system. With that said, I'm sure someone from Texas will say there's works fine. It comes down to what gives you the best comfort for your weather conditions.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
