10-13-2013, 02:46 PM | #26 |
Moderator
Re: rear mounted Fuel tank?
Using a Camaro tank allows you to put the filler behind the license plate. If I ever did this mod again, this is the route Id go. The side marker and taillight ideas are great, but a lot of work and if you live in a state where they have giant rubber boots on the filler nozzles, it's about impossible to fill your tank without making a huge mess
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
10-14-2013, 10:23 PM | #27 |
I have seen a guy used a ford falcon fuel tank...fit was really well but not sure what he used for a sending unit...
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
05-07-2016, 09:08 PM | #28 |
I am using two stock Sub tanks. One in OEM location and one behind that cross member, with a trailer hitch, and the trailer connector/winch connectors are going behind the license plate. Yes it is tight but it should work.
I am using the OEM(71') Filler neck on the front tank, got a factory cut out filler neck 1/4 panel mount from Vintagechevytrucks and what I presumed is a 67' Filler neck as the cap from my 71' did not fit. Just got a 67' Cap from my FLAPS and it fits but does not turn... Does anyone know what changed between the caps/filler necks over the years? |
05-07-2016, 10:04 PM | #29 |
http://67-72chevytrucks.com/vboard/a...1&d=1462672888
I put a hagan pop up door in my left rear inner fender. This picture does not show the door installed, but you can get an ideal.
John |
