01-15-2013, 10:18 PM | #26 | |
Re: 4500 mockup begins-eng location ?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
01-25-2013, 09:12 AM | #27 |
I put the bench seat and shifter in yesterday to check for overall fit. It fits great! The angle on both axis' turned out to be spot on.
The throw on the shifter on the 4500 is quite short. Guessing 6 inches max at the knob. The 3 1/4 move fwd turned out to be perfect. |
01-25-2013, 10:27 AM | #28 | |
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
01-25-2013, 12:49 PM | #29 |
So if you've got 3 inches of clearance between the HEI cap and firewall, and you moved the engine forward 3 1/4", that means the cap would've been hitting the firewall had you not moved everything forward
01-26-2013, 10:30 AM | #30 |
I ran it before with the HEI and it didn't hit, but it was darn close. I did have to remove the cap to get the distributer in the in the hole. I really moved it fwd because I have the truck down to the frame and needed to adjust for the 4500 swap.
01-27-2013, 09:46 PM | #31 |
looks good! thanks for posting pictures so i can get some ideas for my project!
1988 GMC V3500 CCLB Cummins P7100 NV4500 NP205 D60 D70 |
02-03-2013, 12:08 AM | #32 |
Re: 4500 mockup begins-xmember and 32 spline frt output is in.
More progress;
Got the trans x-member installed. I had to add a "spacer" (1 1/2 in) to the stock X member to get the trans height correct. Easy mod, using the factory 93 trans mount. Also swapped the new 32 spline front output shaft on the NP 205. That snap ring was a SOB! |
04-06-2013, 12:35 AM | #33 |
60-66 Nut
Any updates on your build?
04-07-2013, 01:14 PM | #34 |
Yes-But not good ones.
Thanks to our government and the sequestration I recently lost my job unexpectedly after 18 years. Needless to say, the truck project will be sitting idle as I try to provide an income to meet my bills and take care of the family. I know I'm not the only one so I'm not complaining. I'm just doing whatever it takes for now to survive. I'll keep off the political soapbox and hope that everybody understands. I hope others in my situation the best of luck. Mike |
04-08-2013, 02:06 AM | #35 |
60-66 Nut
Eighteen years at your job, and then they just let you go is just not right. Very sorry to hear this. I wish the best for you and your family.
04-08-2013, 12:21 PM | #36 |
Good luck Mike
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
04-08-2013, 03:39 PM | #37 |
Hope everything gets back on track for you Mike. That's just not right.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
04-09-2013, 10:23 PM | #38 |
Windy Corner of a Dirty Street
Ah, man! That is horrible Mike. So sorry to hear about that. Hang in there my friend and good luck with the search. The truck will always be there waiting for you once life gets back on track.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
04-25-2013, 08:43 PM | #39 |
My cap touches the firewall. I Will be doing this same swap thanks for the measurements. Good luck
Posted via Mobile Device |
07-03-2013, 09:25 PM | #40 |
Well boys, things are looking up. I landed a new job today and am looking forward to getting back on the project although it will be slow going as the budget is long gone.
The good news is I have 95% of the parts I need already, just going to have to get creative to get it all together on the cheap. I missed this place and all the guys on here. |
07-03-2013, 09:28 PM | #41 | |
07-03-2013, 11:31 PM | #42 |
Welcome back Mike. Get the family and necessities covered then reward yourself with the continuation of your build.
07-04-2013, 01:11 AM | #43 |
60-66 Nut
Glad to hear you found a job. As snj8198 said, take care of the family first.
07-07-2013, 05:40 PM | #44 |
Turning Wrenches Daily
Great to here Mike. WAs in the same boat until about two weeks ago picked up a nice paying job at a hospital up here!. Be getting back to my 64 gmc 3/4 build here quickly. Working on a few things on the fuel injection right now looking forward to your 4500 build. Since I am going to do that trans and a ranger overdrive in the 64
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!! 1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342 2016 Ram Big Horn 4WD parts hauler 2010 Chevy HHR wife new car after the circled problem blew up!!! 1981 Ram D150 /6 auto Wife's sunday driver Living outside Gladewater Texas now working in Longview at the hospital there future project toys: 1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867 |
07-07-2013, 08:23 PM | #45 |
Thanks guys.
08-02-2013, 03:07 PM | #46 |
SunSoaked, Did you have to trim the ends of your engine cradle before you could move it all the way forward?
Eric 1969 K20, 465/205 package |
08-02-2013, 06:52 PM | #47 |
No sir. However there is a slight taper in the existing bolt holes of the x member. The rear set of holes (rearward) are really close but require a little work with a file. (Assuming you move your x member forward the same amount I did). The front ones need drilled in the frame using the existing ones in the x member as a guide. Look close at the 2nd photo of the 1st post in this thread and you can see what I mean.
08-07-2013, 05:25 AM | #48 |
Well I think the one, that i have may be from a car. Its way different. CTW the sifter comes up almost completely between the seat and my under dash ac. I was actual concerned, about that until i saw it in position.
Melbourne forklifts |
08-07-2013, 11:05 PM | #49 |
I'm so jealous of all you guys with overdrive. I just got my truck on the road and here I am reading your threads and planning my own! Darn you!
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
06-09-2015, 11:46 PM | #50 |
Been gone a while, did this ever go anywhere?
