01-01-2013, 11:43 AM | #26 |
Re: Serpentine Belt or Standard Configuration?
Awesome!! Thanks for all the input and the pics, much appreciated!
Happy New Year |
01-01-2013, 12:12 PM | #27 |
Nope, no internal fan here. Looks like I am off to Pull-A-Part this weekend. Then I'll powder coat all my pulleys and brackets while my son paints the block. If only I could convince him it needs to be Chevy Orange!!
01-01-2013, 12:35 PM | #28 |
now i got to thinking i said you could use the factory clutch type fan and iv,e seen were people have without issues , but i only had i think 3" between my water[ump pulley and the radiator and that,s 1 reason i went with an electric fan i don,t know if it was the motor mount,s that i'm using or what. but if you have enough clearance now the ac delete is,t going to change that . i was assuming that you already had the fan on the truck..
01-01-2013, 12:43 PM | #29 |
Actually when I bought it it had an electric fan setup (complete with toggle switch on the dash). I would think that the water pump pulley clearance would be in direct correlation to whether it is a long or short water pump. If I understand correctly a long water pump measures 7" from the block to the pulley. If that is correct, then I have a short water pump for mine measures around 5" IIRC correctly.
My next step was to pull the motor but now I'm thinking that before I do anything else I should probably mock up the new core support, shroud, fan and clutch before I make any more decisions/changes. |
01-01-2013, 04:03 PM | #30 |
Your A/C delete pulley/bracket that you need is available brand new on Rockauto.com for $22.89. Seems a bit less expensive that the EBAY one even after adding a bit for shipping.
It is made by Dorman, and is listed under the Heat & Air conditioning category and is called an A/C Compressor Bypass Pulley, part number 34152. |
01-01-2013, 04:24 PM | #31 | ||
^ I borrowed this pic of the Jegs website. |
01-01-2013, 04:51 PM | #32 |
I'll take a closer look next time I'm at the shop but this one is a Delco and I swore I looked inside and only saw wire winding.
01-01-2013, 05:16 PM | #33 | |
The fan (many of them actually have two) are deeper down inside than stator windings that are readily visible through the case openings. Here is an exploded view: And here is the CS130D rotor assembly (notice the fans on both the front & back of it) I borrowed these pics from http://alternatorparts.com |
01-01-2013, 05:28 PM | #34 |
Well now my curiosity is really peaked, never would have looked in from the back side. Sounds like my alternator may be just fine after all.
01-01-2013, 05:34 PM | #35 | |
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
01-01-2013, 06:00 PM | #36 |
01-01-2013, 07:19 PM | #37 |
hey Barry, is this the bracket you pmed me about . do you have this side or just the driver side
01-01-2013, 07:27 PM | #38 |
I have both of the brackets, I was talking about what appears to be a brace from the top of the manifold to teh back of the tentioner. this pic looks like there are 2 (#'s 20 & 21).
01-01-2013, 07:53 PM | #39 |
yes there is a brace , there was two of them on the setup that i got off the wrecking yard truck but i'm using just one of them here,s a pic of it if you can make it out, also i seen someone on the part,s board selling the serpentine conversion,s he may have the part,s you need
02-02-2013, 12:02 AM | #40 |
Still plays with trucks
What does the back of that A/C delete pulley look like? Does it use all three mounting points or only two? Hard to tell in the diagram & pics.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
02-02-2013, 12:26 AM | #41 | |
02-02-2013, 01:38 AM | #42 |
425hp409
When you use the serpentine system with a reverse rotation water pump you must also use a reverse rotation fan to properly pull the air through the radiator if you don't use an electric fan.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
02-02-2013, 07:30 AM | #43 |
02-02-2013, 07:50 AM | #44 | |
The 4.3 is a 5.7 with #7 and #8 cut off. The rods, pistons, bearings, and all are the same. When we built my buddies 4.3 went bought a full set of .040 over 350 pistons because it was cheaper in a set of 8 than for a set of 6, rings too. Back to the other topic...............I personaly prefer the serpentine setup. Izzz just easy. Only downside is if you blow a belt you loose everything.................
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
07-26-2015, 10:13 AM | #45 |
I was just about to ask the question and found all the answers on this thread . This forum is invaluable when building a 1965 C10
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
