01-06-2013, 05:44 PM | #26 |
Re: Poly MOTOR MOUNTS and TRANNY MOUNTS
OK , those that have not done this, I TOTALLY RECOMMEND IT. I put them in today, good ole south Texas, it will always get warm enough to work on the truck. Anyway, the Transmission mount was bad anyway, but with all the Poly Motor and Transmission mount, took any and all hesitation from the acceleration and drive line out. I wish I would have done these on my 85. There is ALOT more rubber in the motor mounts, kinda wonder why the factory don't use these. Gonna look at doing this to my 2010 Ford F150
2004 Silverado Crewcab (Dark Spiral Gray) |
01-06-2013, 05:52 PM | #27 |
i may go all polyurethane soon. i need more clutch feel. rubber cab and drivline bushings have too much give and let stuff flop around
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
01-06-2013, 05:55 PM | #28 |
I told ya!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
01-06-2013, 06:03 PM | #29 |
BAD BOW-Silverado XST
Anyone that doubts polygraphite should take a ride with me in my truck. Your face imprint will be on the door inside window.
01-06-2013, 07:06 PM | #30 |
The suspension and such will be PolyGraphite. Just didnt think was necessary for the motor and tranny mounts, nothing really moves.
I'm telling you, there is TWICE as much rubber in that clam shell when you put the Poly mounts in there. I didn't use the tie wraps because it was actually easier to pull the frame mounts as well they put it back together. But drilled the rivets and came right apart. If you do it, make sure you pay attention to how the old ones come out, there are tabs and if you get them wrong, you will not get the motor back on the mounts Posted via Mobile Device
01-06-2013, 08:18 PM | #31 |
I use non polygraghite. It's to soft :p just normal poly an zerks work for me
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
02-26-2015, 11:29 AM | #32 |
any pics
02-26-2015, 02:38 PM | #33 |
Theres a reason theu use rubber in all that stuff i had an 88 k put that poly stuff in all the suspension the red looked cool but man that jar the ride up!
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
