#26 |
Re: Dealer Installed A/C for 64-66
![]() YOO HOO! Any help here on this????? |
#27 |
BUMP
#28 |
![]() ![]() Join Date: Apr 2012
Todd, if your just cutting the firewall the assembly manual shows what to do. I did it on my 66 gmc suburban. Gm put punch marks in the firewall where to connect the dots and cut. Was pretty simple. I also have a Chevy air dash to help with the center vent hole if that's needed. Jon
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#29 |
I printed the templates and they were right on the money, maybe your printer is off.
#30 |
My printer is a network copier, and can print to many sizes of paper.
Which size paper did you use? |
#31 |
![]() Join Date: Mar 2005
8.5 x 11 has been the standard paper since typewriters were invented. I'd try that size first and see what you've got. As a last-ditch effort, have someone else print the templates and send them to you or have them send you the dimensions.
You're making this way harder than it needs to be.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#32 |
No need to be rude. I'm not making this harder than it needs to be - I just want to get the printouts the right size. How is that me being difficult?
Actually, there are many sizes of paper that are "standard" size in the printing world, but that's besides the point. The point is that I did print them off in 8.5 x 11, and they were NOT the right size, hence my asking what the scale was on the templates. Anyone who can provide constructive help would be most appreciated. |
#33 |
Senior Enthusiast
Thanks for taking the time to share this.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#34 | |
But, if we're on the subject of Rude, you might want to take a look at post #26 and #27. This is the last post I'll make on this thread, and I hope you have found it to be constructive. I wish you the best of luck, Todd
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 Last edited by chevyrestoguy; 09-28-2013 at 09:05 PM. |
#35 |
It wasn't what you said, but the way you said it that was rude - "8.5 x 11 has been the standard paper since typewriters were invented" was smart-alecky, in the least, and "making it harder than it has to be" sounds rude, as well.
Further, I never implied that your suggestion was rude. Perhaps this is when texting on cell phones, it's often hard to "get" the intention of the texter, as the textee can't hear the voice inflections or see the facial expressions of the one making the comments. As for my posts, #26 & #27 are concerned, they were semi-comical attempts to get someone to answer - preferably the original person who posted the templates - with the scale to which they would print out properly. All I wanted was for the person who posted them to give me the correct scale, as my printer - which is set to a default size of 8.5" x 11" paper, didn't print correctly. |
#36 |
hello i have a vintage system set up in my truck 1966 c10. it isn't functioning properly for some reaso. how do i fix this and where do i start? thanks so much
#37 |
Go out and find an old-school A/C guy and ask him.
#38 |
![]() Join Date: Jun 2011
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
#39 |
I know this is a little late in this thread but here is the hole cut from the factory or dealer on my 66' GMC...it will give you a good idea where it goes. right between the two mounting holes. It was a deluxe under dash Harrison model with three pulls mounted under the radio delete on its own bracket and the regular ash tray was in the dash. No in-dash vents except the defrosters, with two swivel balls vents in unit under dash. The pull cable to the heater box in the engine compartment opened the flap directly behind this hole(in the cab) to allow the fresh air to flow into the unit and the cab. Hope this helps someone...
#40 | |
#41 |
![]() Join Date: Feb 2014
cool now I know where my ashtray goes
#42 |
is there any way to get a copy of the instruction sheet I'm working on a 66c10 with factory ac any help will be appreciated
