Old 01-08-2013, 02:58 PM   #26
68Stepbed
68Stepbed's Avatar
Re: Let's see your - Metal Tube Radiator Hose
Earls makes these beader sets. One of these days, I may buy a set.
http://www.summitracing.com/parts/ear-018erl/overview/
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-14-2013, 12:00 PM   #27
aggie91
I'm just glad to be here!
aggie91's Avatar
Originally Posted by BMERDOC View Post
FWIW, Matco has a bead roller for tubing. I saw it on Horsepower Tv...Haven't found it again since then.
This is not the Matco one, but is made to bead the ends of tubing...
http://www.trick-tools.com/Bead_Form_3_BF3_948
If your doing only one or two, would be to expensive, but if you are going to do a bunch and in different sizes this would be the way to go.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-14-2013, 02:17 PM   #28
RHGuyettejr
RHGuyettejr's Avatar
Here is what I believe to be the factory hose.... I'd imagine you could make one pretty easy from the right sized pipe.
RHGuyettejr is offline   Reply With Quote
Old 01-14-2013, 02:46 PM   #29
rsavage
rsavage's Avatar
Post 17 shows the stock hose on my Blazer.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 12-12-2013, 08:15 PM   #30
74baggedbug
Originally Posted by sdailey View Post
Here you go Nate. This is on a local truck. He used exhaust pipe. One short straight section and one 90.
Really need a upper radiator hose like this 1!!!
74baggedbug is offline   Reply With Quote
Old 12-12-2013, 09:28 PM   #31
BurlyCrew
I've seen a clear hose from somewhere, can't remember where but I thought that was cool, was suppost to be cooler than rubber/metal too...
BurlyCrew is offline   Reply With Quote
Old 12-12-2013, 09:32 PM   #32
74baggedbug
Killerglass.com
Old 12-12-2013, 09:33 PM   #33
BurlyCrew
Old 12-12-2013, 10:20 PM   #34
chipflyer
chipflyer's Avatar
As some have already said the 4x4's originally used them. The engine is set back on a 4x4 (closer to the firewall) and a single hose would have needed to be longer.Some engineer must have decided it would be better to use the metal metal tube to cover the extra distance and make it a little more ridged.
That clear tube is cool!
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 12-12-2013, 10:40 PM   #35
diceman50
I have this one works great.
http://www.aircraftspruce.com/catalo...parkerbead.php
diceman50 is offline   Reply With Quote
Old 12-12-2013, 11:38 PM   #36
pritch
pritch's Avatar
That looks like it's pretty much the same bends as yours, rsavage. For some reason, I've always thought those were a GMC-only thing. Maybe I've just only seen them in person on GMCs
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 05-02-2017, 08:24 AM   #37
midniteblues
midniteblues's Avatar
I have the original that came off my 71 k20 but it has pin holes and alot of pitting in it after a mutric acid bath.
Any ideas on how to save it?
I have one of those ugly ribbed hoses on it for now since that was the longest hose I had on hand.
No I'm not gonna "flex seal" it.lol
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 05-02-2017, 08:59 AM   #38
marysville
Nice set-ups. I've got to say we've got some clean engine bays in the community. Seeing all of these custom autos makes me want to start a meet.
marysville is offline   Reply With Quote
