01-10-2013, 07:39 PM | #26 |
Re: Lengthening a C30 157" frame
#2
Posted via Mobile Device |
01-10-2013, 07:42 PM | #27 |
#3
01-10-2013, 07:44 PM | #28 |
#4
01-10-2013, 07:48 PM | #29 |
Last one.
01-10-2013, 08:37 PM | #30 |
LMFAO paws 72
01-11-2013, 11:05 PM | #31 |
Uncle - thanks for going to the trouble and sending those pics - looks like someone went through a lot of cut/weld/reconfigure to get that very long WB one of our C30s. You have satisfied my curiosity there, much more time/work/$$ than this project calls for. Thanks again.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
01-17-2013, 04:56 AM | #32 |
Found a link that might interest you, see post #33.
http://67-72chevytrucks.com/vboard/s...=491314&page=2
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
01-21-2013, 08:13 PM | #33 |
Thanks SS Tim - that thread does help. Much appreciated.
01-28-2014, 01:23 PM | #34 |
hey guys just reading the thread and theres alot of good tips going around. i am kinda doing the samething but i need to shorting my frame not lengthening. mine is a 68 c30 started life as a motor home. i removed the motor home and am putting a A&W wrecker body. but im not sure if it would be easier to cut my frame or get one of a newer year so i can have easy disk brakes. some my question is does a 68 body bolt on a newer frame?
01-28-2014, 02:11 PM | #35 | |
the boat guy
Id cut the frame down before. Did a chassis swap.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-28-2014, 02:16 PM | #36 |
Cutting down the frame 24" is a project.
Remeber driveshafts and brake lines need rework too. IIRC the only real frame difference going to later frame would be the front core support mounts. The disc brake front end is a bolt on up through the late 80s. Wrecker use is very hard on fromes especially side pulls of any real angle. Make sure your modifications are up to it.
01-28-2014, 02:22 PM | #37 |
thanks guys. im not going to use the truck everyday more or less just something differnt. im also considering making it 4x4 so if thats the case a frame swap would be the best choice. its also getting a first gen cummins and 5 speed. something kinda differnt
