Old 01-10-2013, 07:04 AM   #26
70c10stepside
Re: Holley Question
You're in Gainesville Not to far down the road. Those are some really solid numbers! Thanks for the input man
70c10stepside is offline   Reply With Quote
Old 01-10-2013, 11:12 AM   #27
Moline_Puller
Moline_Puller's Avatar
Re: Holley Question
From what I've found, a lot depends on your rpm range...an engine is basically just an air pump really. The faster is is running, the more air you are moving through it and the more fuel you will need. If you are not running a lot of r's, and are looking for MPG, then the 600-650, should be fine. If you are screaming it and looking for performance, then go with the 750.
Here is a link to a CFM calculator...
http://www.4secondsflat.com/Carb_CFM_Calculator.html
Play around with the engine size and the rpm range, and you can see what I mean. The 83% is if you are running a carb, versus 100% for EFI.
Hope this helps!
Chris
Moline_Puller is offline   Reply With Quote
Old 01-10-2013, 01:43 PM   #28
70c10stepside
Re: Holley Question
Yeah, I see what you mean. I would like the 670 street avenger, its just 100 bucks more. And, I am also in a fund for tires.. Thats why I am leaning more so towards the 750. And with it being vacuum secondary, and so tuneable and everything. Its probably what I'll go for. The truck is not a dd, it gets drove maybe 2-3 times a week lol Its me and my dads toy. In the future we plan to go 383 with a much more agressive cam and a few other thing to be changed. So, yeah.. And we drive it, its tops a 20 mile round trip.
Old 01-10-2013, 05:19 PM   #29
eldogg
eldogg's Avatar
Re: Holley Question
Let me know if I can help. I have a few core carbs in stock I could build if you need one, and if you get one and need it tuned up give me a shout.
eldogg is offline   Reply With Quote
Old 01-10-2013, 05:28 PM   #30
70c10stepside
Re: Holley Question
Will do! Thanks!
Old 01-10-2013, 08:16 PM   #31
cheviss427
Re: Holley Question
try looking for a holley 650 spreadbore, small primaries and large secondaries....just my 2cts.
cheviss427 is offline   Reply With Quote
Old 01-10-2013, 08:35 PM   #32
70c10stepside
Re: Holley Question
The 750 will be here tomorrow :P After a got word from Holley, we just went ahead.
