#26 |
Re: Backyard Charging Tests failed
this would be your best bet.I did this with my Burb,my lights stayed brighter,it was a good conversion.
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#27 |
in all my years i have never heard of that magnetism trick. i wouldn't go by that.
sounds like you have a broken wire from the regulator to the alt, the alt is not being told to charge. or you have a defective part. when i bought a engine for my truck i took the alternator and starter to a local starter rebuild shop, he asked me if I'd like it upgraded to a 1 wire, i said sure, either them work or they dont, everything including the regulator internal. it was the same price too. I'll have to look to see what i did with the unused wires. I think i zip tied them to the wires on the regulator, the hot post is in the same place, just the regulator wires are not needed any longer. |
#28 | |
![]() ![]() Thanx! Last edited by Blainethemono; 02-23-2013 at 09:00 PM. |
#29 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
