01-13-2013, 05:59 PM | #26 |
Parts and more parts
Re: Totally disgusted - flat cam
My guess is that your oil type was not the issue with the failure. Especially 500 miles on the engine. The fact of the matter, is that you said that you were using a break-in oil, so you should have been protected. The discussion for zinc in the oil is a good item to consider. That would leave two possibilities---the cam material failed or you could have had an oiling passage failure. I would go throught the whole set of oil galleys to make sure that they are clean before reassmbly again. Been there, felt the pain.
Frank |
01-13-2013, 06:07 PM | #27 | |
When using high zinc oils, the catalytic converters get covered with a zinc coating, limiting life to around 60,000 miles. To meet the EPA's mandates, car manufactures worked with the API to create new, lower Zinc oils that allow catalytic converters to run for over 120,000 miles. I found an oil dealer in Great Falls that carries military spec oil. 1400 ppm is zinc. |
01-13-2013, 06:11 PM | #28 |
It sounds like you did everything right, and unfortuately just got stuck with defective parts.
Personally, I think the quality of parts has really declined in recent years. ( I have never used comp cams. I heard too many stories of lobe failures, even before the zinc was removed from motor oil) I would never buy one. I spent 40 years working on cars and trucks for a living, built more engines than I can remember, and never once had a cam failure. Just my own personal opinion, for whatever it's worth, I think the folks at comp cams owe you an apology as well as an engine rebuild.
"Negative people always seem to have a problem for every solution" |
01-13-2013, 06:21 PM | #29 | |
Jeff Horsman 1972 C20 Highlander "C" 1966 Olds 442 L69 four speed 1971 Skylark (GS clone racecar) 494 stroker 1986 Buick T-Type |
01-13-2013, 06:24 PM | #30 |
"I spent 40 years working on cars and trucks for a living, built more engines than I can remember, and never once had a cam failure."
Actually, I remember having one cam failure back in 1973 when I was dumb enough to install a used cam without using new lifters.
01-13-2013, 07:18 PM | #31 |
Well it sounds like a bad camshaft!! Back in the late 70's and earley eighties chevy had a big problem with theres!!! I worked at a chevy dealer then and we used there replacement cams/lifters only to have them fail again!!! I did my share of them, under warranty! We got smart and started using reground cams from the 70's with new lifters from the local machine shop,we never had one come back.We used breakin lube on both. If it was me,I would NEVER buy a comp product again!! Roller or what ever. To many other options,that have a good company reputation. They stick to customer satisfaction!!If you still have the original break in oil, You can have that oil analized,and it will determine what is in the oil,and it may determine the cause of your failure. Good luck
01-13-2013, 07:39 PM | #32 |
I guess that's one way to sell their roller cams. it's always easier to just blame the customer than to stand behind your products.
01-13-2013, 07:52 PM | #33 |
I have an engine builder that has changed over to the Synergyn products for every engine that he puts out the door. He also runs it in his vehicles daily.
As for cam failures, GM had some serious issues in the past with flat lobes on their cams and I had to pull a few as a mechanic for a fleet of trucks. I have a comp roller cam in my stroker engine, but my son'e truck has a Crane non-roller cam in it and it is working great to date. Personally I would pull the engine and inspect the cam bearings, rod bearings, and oil galleys for any debris. You have too much in it now to do just a rudimentary repair on it. http://www.synergynracing.com/
Frank |
01-13-2013, 08:34 PM | #34 |
Well, I have to say that this causes me concern. I have a mild 355 on the engine stand about ready to go in my '63. It has a New Comp cam and lifter set in it already. I have used Gibbs cam and lifter grease and i am planning to use Gibbs break in oil. My machine shop reworked my heads and set up the valve springs to work with that cam...I will follow the machine shops breakin procedures and see how it goes.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
01-13-2013, 08:35 PM | #35 |
Yep, I was working for a Chevy dealer back in the early eighties, so I remember the cam problems.
I have had very good service from Crane cams in the past. I don't know if their quality is still what it used to be though.
01-13-2013, 08:50 PM | #36 | |
For me personally, it will be a cold day in a very warm place before I will ever buy one.
01-13-2013, 08:59 PM | #37 | |
Having to pull my engine and completely start over is pure hell to me.
01-13-2013, 09:18 PM | #38 | |
It'll Buff Out!
x2
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
01-13-2013, 09:32 PM | #39 |
I've only seen a couple flat lobes in my time.
but the worst was when bigg $$$ was spent on a fresh bb and it ate the cam after break in I'm glad is wasnt mine but I'll tell ya i sure felt his pain knowing what he had into the engine. Yours looks so clean I too would hate too have too tear back into it.like others said it makes a roller sound like the ovious choice.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
01-13-2013, 09:35 PM | #40 | |
01-13-2013, 10:11 PM | #41 |
It's not that hard to pull the front clip. Most of the pieces you are unhooking when you pull the engine anyway, radiator hoses, battery cables, etc.
Unbolt the core support from the frame, cowl panel, fenders from the cab, and away you go. Of course you have to draw the line somewhere or else the truck will be in 30 pieces before the end of the day.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-13-2013, 10:13 PM | #42 |
I hear ya on that I'm about too do it the same way
01-14-2013, 12:23 AM | #43 |
My Carbon Footprint
You leave that motor in and just install a new cam, even if it's a roller (which is what I did), you are nuts. You have a great chance of losing the entire motor. Look through this thread and look at my posts/pics. I have been right where you are at. You want to see what a wiped lobe does to bearings???? Look on....
http://67-72chevytrucks.com/vboard/s...d.php?t=557288 My heart goes out to you. That has to be the worse pit in your stomach. |
01-14-2013, 04:17 AM | #44 | ||
"I ain't nobody, dork."
It happed to me as well... So I feel your pain. There was so much garbage in my oil, that I lost a crank as well. The amount of metal particles that was throughout the entire engine was crazy. You should have seen how much was under the baffle in the oil pan alone. What I learned is that after the initial cam break in. CHANGE THE OIL. Do not run the break in oil for 500 miles like we used to in the olden days.
If I do a flat tappet cam... I break it in using straight 30wt oil with Comp Cams break in additive. Do the break in procedure and then CHANGE THE OIL to 10w30 with ZDDP additive. I will then drive the rig for about 200 miles and CHANGE THE OIL. Again using 10w30 and a ZDDP additive. Then I go to my normal oil change routine. Haven't had one go flat since. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
01-14-2013, 07:53 AM | #45 |
I removed the 402 in my restored cheyenne super without tranny. Just take ur time. Id remove the radiator and all of that too. If u pull distributor its easy to get at top tranny bolts. Good luck and sorry to hear about ur luck.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
01-14-2013, 11:52 AM | #46 |
I've built dozens of engines, possibly hundreds, in the last 25 yrs-the only engine failure I've ever had was a Comp cam way back in the '90s-was an exhaust lobe on a 289. I thought I did everything right(break-in etc), Comp warranteed the cam but nothing else.
I like using a WIX racing filter 51060R during break in, more flow + more filtration. |
01-14-2013, 12:06 PM | #47 |
I plan on putting in a cam this winter, and this has worried the heck out of me. My buddy just had 2 lobes go flat in about 200 miles, ruined a fresh big block in his trans am. What is the cost difference in going with a roller set up?
Posted via Mobile Device |
01-14-2013, 12:18 PM | #48 |
I had the same thing happen to my 454 after 11 miles , my machinist told me when I built it to put a roller set up in it because the lack of zink in the oil was killing lobes on all cams. I didn't so I had to do a second rebulid plus a valve job on a brand new set of heads. I feel your pain.
1967 swb 454 cid 700R4 trans SOLD 2006 Chevy Trailblazer SS 2013 Camaro RS convertible the wife's Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248 |
01-14-2013, 12:20 PM | #49 |
Looks like $500+.
01-14-2013, 12:36 PM | #50 |
I put a used 25 year old comp cam in my 327 back in june and haven't had an issue yet I feel that the newer cams aren't as strong as they use to be
