#26 |
Old member
Make sure the spring is long enough. As I stated before I had to strecth mine for it to work good.
Do you see it sparking when you put it together? ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#27 |
Re: How does the steering wheel horn button mount?
Not sure if this is your problem, but it looks like you have painted the inside portion of your column, and it may not be getting a path to ground when depressed. My column is bare metal underneath the plate that you have shown.
#28 |
Old member
I went and snaped some pictures of mine for you.
71Sixer, he makes a good point! Didn't even think about that. ![]() ![]()
#29 | |
I did notice on the brothers site, that while they do sell 67/68 steering wheels, they don't sell the horn contact button parts. I called them, and they confirmed that they don't sell them, and that they are different from 69-72 steering wheels. So, I guess I need to find a used one somewhere? Posted via Mobile Device |
#30 |
I had troubles getting my 67 back together the right way when I replaced my turn signal switch. Difference is I am in the middle of nowhere lol. Just kept flipping things around until it worked correctly. I like the idea of unplugging the horn. Still lets you hear the relay click. GL with the neighbors.
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
#31 | |
The Older Generation
Like mentioned, the paint is probably your problem. It has to be bare metal below the disk. Also you have to be very careful that the metal disk is not pinched under the plastic standoff. In your bottom picture, if you look at the center hole it looks like the disk is not centered under the metal cup. LockDoc LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-17-2013 at 12:39 AM. |
#32 | |
#33 |
I was lookin at "truckshops"orange,ca catalog and it says that the horn cap retainer kit fits 69-72. Doesnt even show for 67-68. I hope I have all the pieces for my 67. I still am in need of a horn itself. Hope it all works out for ya.
Stovebolt-It is painted |
#34 | |
#35 |
This is out of the parts catalog. Did you try looking in the 68 manuals?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
