Old 01-26-2013, 10:27 PM   #26
padresag
Re: 4x4 Power Steering
Originally Posted by 61K10 View Post
don't know if i will run the rims--15x8, not going to be a real off road truck as i am an old-- 63 yrs and just want a nice driver if it snows (have a 2000 z71) I like old stuff like me and I have been modding stuff before most of you were born, and would keep an eye on stuff that would be in a pressure zone. take care all------
I don't go off road that much either and I doubt that you have been doing it since before I was born as I will be 5 years older than you in the upcoming week. Just glad that I am not as old as Stodder though. I think that he is the old fart on the board.
ron
padresag is offline   Reply With Quote
Old 01-26-2013, 11:11 PM   #27
Jwernquist
I'm building the truck for a fun winter driver as well. Rims are original or that era. I'm not putting monsters on it. Ill take your advice just bolting the brace. The truck won't be offroaded at least on purpose . The power steering is just for ease of daily use.
Jwernquist is offline   Reply With Quote
Old 01-27-2013, 01:01 PM   #28
61K10
61K10's Avatar
Happy B-day Ron! wow, somebody here thats older than me and still works on this old stuff. I should of known you've been around as the great info you post on here. I do have a set of toyoda 17x7 or 7 1/2 with 4 1/2 bs that came on the truck. the 15x8 rims were given to me by my neighbor. trying to save some $$$ somewhere. still need to rebuild the eng and running gear after pulling the cab.
kimble
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-27-2013, 10:55 PM   #29
61K10
61K10's Avatar
Is this steering stop org? looks a add on to me? with my new steering my knuckles are about 1/2" from hitting them. don't remember where they were with the manual steering.
1961 chevy K10
Old 01-28-2013, 01:59 AM   #30
padresag
you didn't shorten the steering arm did you. you may not be getting enough travel from the new box(it may not travel far enough to get it there), if you shorten the steering arm that will mean less travel for the pitman arm
I will make a measure on the one that I have here tomorrow if you like. mine hit the stops. one way to check it is to disconnect the drag link from the pitman arm and check the travel. young fellow like you should be able to figure that out
ron
Old 01-28-2013, 04:57 PM   #31
61K10
61K10's Avatar
no i didn't shorten the arm (yet) the stops look stock as some other axles i have found pics of. probably still turn as good as my 2000 Z71 extended cab. a friend has a 1 ton 4x4 ford crew long bed, talk about wide turning radius. wanted to get some of the frame stuff done before blasting and paint.
1961 chevy K10
Old 01-28-2013, 05:18 PM   #32
padresag
Mine turned really well with the p/s and the orig axle
ron
Old 01-29-2013, 12:56 PM   #33
61K10
61K10's Avatar
was that the one with the shortened arm, or with a stock arm?
1961 chevy K10
Old 01-29-2013, 01:23 PM   #34
padresag
that would be with the shortened arm. the length of the one that I have is 7 3/8" from the centre of the k/pin axis to the centre of the drag link end hole
ron
Old 01-29-2013, 01:24 PM   #35
j.kirn
61K10 you didnt forget about me did you
j.kirn is offline   Reply With Quote
Old 01-29-2013, 02:41 PM   #36
61K10
61K10's Avatar
j.kirn--------I was waiting for you to chime in, and no i didn't forget about you.
1961 chevy K10
Old 01-29-2013, 02:50 PM   #37
61K10
61K10's Avatar
thanks for the pic Ron. my truck is not street-able as you can see. waiting on a belt for the PS. should come today. my drag link is not parallel with my spring, off a little and shortening would cure that. don't know if that is going to be a problem.
Jwarnquist---how about a pic of your shortened arm?
1961 chevy K10
Old 01-29-2013, 04:18 PM   #38
padresag
that steering arm was done up over 30 years ago
ron
Old 01-29-2013, 05:24 PM   #39
61K10
61K10's Avatar
got my belt and the pump is no good!!!!! old and used of course. just wanted to see if my used box is. any good. it's only $$$$$$$
1961 chevy K10
Old 02-01-2013, 11:25 AM   #40
hamllik
hamllik's Avatar
Thanks for all the helpful info. There sure isn't a lot out there on 4x4's. I was wondering in the picks of the original steering arm on the axle I see a ball joint sticking up. How did you remove it? If I am reading correctly the hole was tapered when it was removed? How much did the new steering parts run you? Sorry for all the questions, but I want to have all my ducks in a row. I really like the fact that you guys post lots of pictures it sure helps.
hamllik is offline   Reply With Quote
Old 02-01-2013, 01:48 PM   #41
61K10
61K10's Avatar
the ball that is sticking up is for the stock drag link rod (shaft) it is a taper fit like a regular tie rod end. $$$ depends on new or used steering box/pump/brackets/hoses and autozone or moog parts and captfabs mounting plate.
1961 chevy K10
Old 02-04-2013, 01:25 PM   #42
61K10
61K10's Avatar
we have power steering!!!!!!!! it actually works.
jwernquist------didn't mean to hi-jack your thread, but there is not much info about P/S on the 60-66 K trucks. did you get your steering arm back? Pic? hope your threads info helps others.
1961 chevy K10
Old 02-04-2013, 06:06 PM   #43
61K10
61K10's Avatar
thats what i hope also. my used P/S box leaks-----another rebuild (looks like the steering shaft out of the box to column shaft)
1961 chevy K10
Old 02-04-2013, 07:30 PM   #44
padresag
and usually it is the shaft worn where the seal sits. the dirt and grime sits on top of the seal and encourages wear there. usually easier to just put in a new box.
ron
Old 02-04-2013, 09:34 PM   #45
61K10
61K10's Avatar
funny it quit--we will see as i have a long way to go on everything else. thanks for all the info for this project--------
1961 chevy K10
Old 02-15-2013, 01:49 PM   #46
61K10
61K10's Avatar
power steering is up and working. one thing that we talked about in this swap is the steering arm. It definitely has to be shortened. the axle doesn't turn good as is (stock) it really doesn't now. I have a longer pitman arm i might try?--the stock steering arm looks like you could just cut the end off and re-drill a new hole and taper it. it could be heated and bent up so it's level? and no i'm not swapping axles. (should never say that)
put in a tilt column ($159.00) off e-bay-----junk!!!!! another story.
1961 chevy K10
Old 02-15-2013, 02:04 PM   #47
padresag
like I said my steering arm is avail
ron
Old 02-28-2013, 12:21 AM   #48
hamllik
hamllik's Avatar
I have a question about locating the power steering box. Did you use any of the original steering box holes to locate the new box and brackets.
Old 02-28-2013, 02:17 PM   #49
61K10
61K10's Avatar
my post #21 shows only 1 bolt.
1961 chevy K10
Old 03-24-2014, 11:43 PM   #50
BigSix
I may have missed it but did anyone mention what model front axle you were working on? My 3/4 ton 4x4 is Dana 44 front...is that what you guys are working with too?
BigSix is offline   Reply With Quote
