Old 05-20-2014, 02:41 AM   #26
andrewmp6
Re: Lifting my 90 model k5
Have you looked at http://offroaddesign.com/catalog.htm
andrewmp6 is offline   Reply With Quote
Old 05-20-2014, 06:39 AM   #27
chevymadness
I was just going to reply on this thread in furry about running 35s because I think it's extra beef to carry for no good reason unless you mud or do sport and it's more gas which ticks me off.But after seeing bohman kids pickup I changed my mind real fast.And on a shackle flip I think is terrible talking about a dangerous and out of wack and bouncy type of lift I wouldn't abuse my truck with that crap.
1982 chevy silverado
It's all about original guys original let me say again original.
chevymadness is offline   Reply With Quote
Old 05-20-2014, 08:32 AM   #28
When talking what fits with tires and lifts we see answers all over the place. The reason is,for the most part,people forget to list the wheel width. That is the make or break factor on many lift/tire combos. I run a 4" spring lift with 315/75s on my '85 Jimmy and I can rub the fenders. That's because I am running 10" wheels. I'm willing to bet with 8" they wouldn't rub...or only in extreme maneuvers. In my opinion,for the quality,ride,and cost,you can't beat Tuff Country EZ-Rides. That's what I've been running on the last few lifted trucks I've had
Old 05-20-2014, 09:15 AM   #29
Your41Plague12
Your41Plague12's Avatar
Go with a Tuff Country lift and EZ Ride springs. Best spring rate around for a readily-available lift kit. I had a Rough Country 6" kit on mine, and I literally dented my roof hitting a speed bump at about 3 mph. No suspension flex at all, axles may as well have been welded to the frame. The only suspension I had was the cushion in my seat.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 05-20-2014, 02:21 PM   #30
Ski-me
Ski-me's Avatar
Originally Posted by DetroitDan View Post
I had a 91 Blazer last year with a 4 inch all-spring lift and BFG 35s. Could get them to rub hitting a bump while turning (into my driveway, every day) so I clearanced it with a sawzall just a little. Had 3.08s and a 700r4 behind a tbi 350, too much tire height for those gears, but I would definitely not recommend 4.56s. Way too much imo. 3.73s would be enough to satisfy most, 4.10s are pretty much ideal. Keep in mind, your carriers won't support a drastic swap. May want to consider swapping in 3/4 axles, easy swap. Radial tires rarely measure anywhere near their stated size, so you're probably only getting a 33 anyway.
Hey Ski-me, are you sure that's only 2.5 inches of lift?! Mine had the same exact tires and yours is as tall, probably taller. I would have bet that was a six inch lift. Doesnt look like theres any bodylift there either.
Sorry man, missed your question from way back....But yes, it is only a 2.5" lift from BDS. In fact, I felt that it was just a "little springy" so I took one leaf out up front. It now rides more smoothly too. Block in rear measures a little over 2" and the rear springs are new, stock height replacements.
15x10 wheels.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 05-20-2014, 10:48 PM   #31
Zoomad75
K5Camper
Zoomad75's Avatar
I'm baffled when people blast shackle flips as dangerous. More so when you look at earlier trucks and other leaf spring suspensions have been used with the similar tension (shackle pointing down) shackle position with no ill effects at all. It's not unsafe. I've run a flip on my K5 for years with no ill effects other than fixing the crappy pinion angle my rear diff had before the lift and making the ride nice and soft. It's a very effective way to maintain factory spring rate and gain lift without a rough ride of high arched springs.
Now out front, I've got a set of 4" rough country springs. Not ideal, but have done the job well over the years. It's firm but not spine jarring, but I think having the rear being soft does seem to off set it some. For the price, which was a big issue for me, they are just fine. I've not felt the need to go with softer spring rate springs up front.
I'm running 35x12.50's and had a small rub at the front lower fender area with the suspension twisted up and the wheels turned. I chopped the bottom 4" off the front fenders and solved that problem, but a small shave on the lip would have solved it.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 05-21-2014, 02:46 AM   #32
jbristo67
resident oilfield trash
jbristo67's Avatar
Chevymaddness I'm not sure if you noticed but I work in the oil and gas industry. Fuel economy is not my top priority. That being said I'm not building this truck for you. I'm glad you approve now though.
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
