#26 |
![]() Join Date: Aug 2008
Re: Extra parts i need gone
How much for the wiper arms with Trico blade holders shipped to Leander TX 78641?
#27 |
Payment sent. Thank You
Posted via Mobile Device |
#28 |
Wideside i do not have the linkage part by it self . On the wiper arms shiped to you $28.70
#29 |
I set of turn signels & marker lights 1 set of pulleys are sold the glove box door is pending i am open to offers
#30 |
Monday bump
#31 |
![]() Join Date: Jan 2013
Do you have a set of ram horn manifolds left? I really only need pass side
but will take both if not cracked. Jamie |
#32 |
I need a horn/turn sig/flasher harness if not cut up or broken. My column
is non tilt. Also if you have the wire & light for an auto shift indicator i need that too. thanks Jamie |
#33 |
Is your truck 2wd if so i do have 1 set left should have everything you need i will look through my stuff tomorrow what year truck are you working on ?
#34 |
Got my stuff, very nice! thank you
#35 |
Wetowm: We're you replying to my thread? So many people on here I wasn't
sure lol. |
#36 |
Do you have any power steering brackets for a short pump small block?
Thanks-Mika |
#37 |
I have 1 left it is the brackerts & pump and pulley i aalso have the crank & waterpump pulleys if you need them
#38 |
I just need the pump brackets. Can you send pictures of them?
Thanks-Mika |
#39 |
Ya i am not going to split them up sorry
#40 |
How much for the brackets, pump and pully?
Mika |
#41 |
![]() Join Date: May 2011
do you still have the Middle column housing? was that for tilt or non tilt?
#42 |
Non tilt
#43 |
Pictures for oddfire
#44 |
When I bought that power steering setup and steering column from you last year I should have bought the pulleys also. I finally got around to installing the power steering setup and I installed a crank pulley from a different engine I had. Well they don't line up. Any chance you still have a pulley set up off a smallblock with power steering and a short water pump?
-Scott- |
#45 |
I do, dam i was just passing through your way yesterday has to look at some parts in nixa
#46 |
Think we could work out a deal on them? Probably have to have them shipped unless you are coming back this way soon. I don't see myself headed to St. Louis for a while. But I might be going to Fenton soon to get my work truck fixed. Anyway, lets talk about shipping the pulleys and we will go from there.
-Scott- |
#47 |
SJARRETT71 $38.00 shiped
#48 |
Do you think you can post some pics of the pulley(s)? Do I just need the bolt on third pulley or is it the solid three groove pulley? The pulley I had came off a 69 350 with a short pump so I thought it would just bolt on and line up.
-Scott- |
#49 |
Is is the outside pulley this is the last 3 groove set i have dont want to split it up
#50 |
ok that looks like what i need. how would you like payment?
-Scott- |
