02-02-2013, 08:48 AM | #26 |
Re: Psi harness where to mount computer
is that where it's goin?....wont it get really hot there?
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
02-02-2013, 09:34 AM | #27 |
Thats where its going. Gotta remember these computer's are weatherproof and gm puts them in the engine compartment. Alot of other members have also put there computer in this spot as well.
Posted via Mobile Device |
02-02-2013, 10:27 AM | #28 |
I used the factory mount, cut it to fit to a frame made from 2x3 angle, and mounted it on the drivers side of the core support beside the radiator. It doesn't get hot and is out of the way and looks nice.
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy C-30 1-ton 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2005 Dodge Ram 2500 5.9 Cummins 2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins 2020 Jeep Wrangler Unlimited Rubicon |
02-02-2013, 10:38 AM | #29 | |
02-02-2013, 08:43 PM | #30 |
mounted mike in the glove box, went through on the firewall on the right side....looks clean, and no wires showing.
02-03-2013, 10:40 AM | #31 |
That will work great. How do u like the psi harness?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-03-2013, 11:23 AM | #32 |
02-07-2013, 11:03 PM | #33 |
02-08-2013, 01:08 PM | #34 | |
Don't get me wrong...the harness is good quality and my truck fired up on the first try...but some of the wiring was a little confusing. The guy helping me with it has done several swaps and he was having trouble figuring out a few wires. I will also say that Don at PSI was always willing to help when we called with questions.
My 85 LQ4 Build |
02-08-2013, 11:49 PM | #35 |
A day late and $1 short...
Mine came with very detail instructions that called out the wires by color and location. It was a first time for me and went very well. I dealt with Jon and the customer support was outstanding, he even answered emails at 9pm on Sunday night!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
04-25-2013, 07:00 PM | #36 |
Fixeruper, did you are tat mount or buy it somewhere?
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
04-25-2013, 08:05 PM | #37 |
Update to my mounting... I built a sheet metal glove box and mounted the ECM to the back. I cut a hole for the relay/fuse center on one side and mounted the Classic Instruments signal converter to the other. I like it better than my first plan and now I have room for a vintage air unit!
04-25-2013, 10:40 PM | #38 |
04-26-2013, 08:24 PM | #39 |
Thanks, and sorry, I just realized I didn't type my earlier post worth a flip. But I guess you knew what I meant.
04-26-2013, 10:44 PM | #40 |
Nice glovebox. I'm having the same dilemma. My vintage air takes up a ton of space. Even with the glovebox out there isn't a great place to mount it. I'm still working on a good place as we speak.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
04-30-2013, 01:35 AM | #41 |
Installed my vintage air last weekend. No way the ecm would work in the glovebox
04-30-2013, 02:41 AM | #42 |
I've got the vintage air in mine too. Gauges out and glovebox out just trying to find somewhere to put it. Thought it might fit on top of the radio under where the speaker should normally go, but the ac vent work is in the way! This is very frustrating!
04-30-2013, 07:39 AM | #43 | ||
04-30-2013, 11:49 AM | #44 |
Mine is the sure fit system.
04-30-2013, 08:32 PM | #45 |
Sure fit magnum IV. Just not enough room. It would be awesome to put the comp under the seat but most harnesses are not long enough. I just took the easy way out and put it on the firewall like pics above.
