#26 |
Re: So mad !! new tranny did not bolt up !!!
speedo gear------
1961 chevy K10 my build is------------61K10 build |
#27 |
I would not waste my time with a th350 !!Put a 700r4 in it!!if i had a 700r4 right now you could have my th350!!
#28 |
And my engine is in the rear position and i have a one piece drive shaft so another 3 inches forward with a 700r4 and boom no more prius passing me on the freeway!!
#29 |
ok so I took off the original flywheel and its a 14 inch 168 tooth flywheel. the flywheel did not bolt up to the th350 torque convertor , so I guess I need a new one. also I took a pic of the bolt holes on the block , is this a staggered or straight bolt pattern ?
#30 |
this may help clarify what holes to use ,cant tell withe all the grime what you have for holes but looks like you have at least a staggered setup ,look at the link if your block has both holes threaded besides the blue circled hole you should be able to use either style starter and corresponding plate:
http://www.crankshaftcoalition.com/w...tarter_pad.jpg
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 Last edited by losthope; 03-02-2013 at 12:07 AM. |
#31 |
Since we are talking about trannies, does anyone know if a 1991 s10 5 speed manual transmission will bolt up to a 1962 235 i6 motor? Thanks for any help.
Current project (My Maria) 62 Chevrolet LWB stepside ![]() 235 inline 6 cylinder http://67-72chevytrucks.com/vboard/s...d.php?t=569873 Dano |
#32 |
pretty sure the t5 will !! look in the faq section!!
#33 |
The T5 is that what that particular transmission is called? Sorry for the dum questions but i sure don't know. Thanks and I will look in the question part.
#34 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
The bellhousing bolt pattern and size is different than the '63 and up I6's and all small blocks and big blocks. So you will need to keep your original bellhousing.
#35 |
Thanks for all the help guys. It has been very helpful. Now all I have to do is find a Brog Warner T5 and I will be good to go. Thanks all.
