02-03-2013, 12:25 PM | #26 |
Re: I need help with what overdrive to install.
How does it work on a 4wd.? does it go inbetween the tranny and TC then.?
And then it just has a another gear inbetween all the other gears so it does not have a very big span between gears then and then the last gear is your over drive. seems like it would make shifting pretty seemless or smoother. |
02-03-2013, 12:32 PM | #27 |
they work only in 2 wd. Unless you have a divorce transfer case Then you can have 4wd with the gear splitting.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-03-2013, 12:37 PM | #28 |
There is a lock out function that locks out the GV when you shift into 4 wheel drive
69 Chevy 4x4 383 Power |
02-04-2013, 07:19 AM | #29 | |
Eventually my plans are running a TH475/GV in front of a divorced203/205 t-case. In use, it overdrives each gear so there is about half the rpm drop between gears as it works up automatically from a stop. Starts out in first gear (1st), hits O/D shift point then O/Ds first gear (2nd) until trans. upshifts to second (3rd). At the same time the O/D reverts to direct drive. Progressing up in second gear (3rd) until it hits the O/D shift point again it O/Ds second gear (4th) until the trans shifts into third (5th). At the same time the O/D reverts to direct drive. Then it progresses up in third gear (5th) until it hits the O/D shift point again, then it O/Ds third gear (6th). This is all very smooth.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-27-2013, 10:05 AM | #30 |
Jocko that chart is awsome but I have different actual outcome than the chart with my truck.
Mine is a 67 C20 with a 400 and 4.10's but my tach is sitting around 2900 rpms at 55 mph. That mph is actually going off of GPS since the speedo isnt accurate. That now has me wondering what my issue is. I am actually considering converting to a 700r4 (have 1 sitting) and changing to a 14 bolt rear with 3.73's to make it more highway friendly. I live 6 miles outside of town and have only driven it in once because it sounds like the motor is gonna shoot pistons at 65 mph.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
02-27-2013, 10:12 AM | #31 |
C/10 junkie
I just did a 4 speed granny box manual to an auto 700r4. I will never look back. Check the last few pages of my build thread for the details.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
02-27-2013, 10:16 AM | #32 | |
haysonj in a previous post in this thread said his goes 1-1od-2od-3od when in auotmatic mode. seems like he is skipping the "normal" 2 and 3 gears and going direct to OD on those. So is that factory set or a laptop hookup or a knob or what? |
02-27-2013, 11:55 AM | #33 | |
