Old 02-02-2013, 06:45 PM   #26
burnin oil
Re: 3spd manual trans crossmember-where is it?
Originally Posted by MARKDTN View Post
Just FYI most class-8 trucks (18 wheeler) mount the engine to the frame with 4 point mounts and the transmission is just mounted to it with no support. If they do have a support, it is usually just a plate with some springs.
I have seen a ton of Eatons with mounts. Top of the rear box has 2 5/8" studs that help support it from above. Then 2 mounts on the flywheel adapter and a mount on the front of the motor. It is pretty common to hang the trans of the rear with no adapter.
burnin oil is offline   Reply With Quote
Old 02-02-2013, 10:31 PM   #27
54belair
54belair's Avatar
When I bought my truck, it had originally been a std. trans. truck, the p.o. changed it to a 700r--torched out "most" of the original std. crossmember and added some rear cross member out of something for the rear of the 700r.
I am changing over to a muncie m 20. Ill be using the auto crossmember from gmc pauls at the rear of the trans.
Ive built several cars down thru the years and I really dont like the trans hanging out in space. Just my opinion.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 03-20-2013, 02:30 AM   #28
2002yanks
i had a question about this crossmember in the suspension fourms. so could one get an auto aftermarket one and place it at the back of the tranny and remove this one? i ask because i want to lay frame(or close to it) and this one is clearly in the way. i never noticed a set of holes there(but i wasnt looking either).
My build thread!! http://67-72chevytrucks.com/vboard/s...d.php?t=474018
2002yanks is offline   Reply With Quote
Old 03-20-2013, 06:23 AM   #29
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If you have a Saginaw 3 speed, there should be a provision for the rear mount cast into the case, allowing you to use a rear crossmember.
If you have a Muncie 3 speed, there won't be mount provisions there.
Old 03-20-2013, 07:20 AM   #30
b.eddy's72
b.eddy's72's Avatar
Well I have to say that I looked at all the post but the only one that caught my attention was the one with the nice pretty clean fresh frame. And they say men are visual creatures............................
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline   Reply With Quote
Old 03-20-2013, 11:24 AM   #31
dhaymaker
dhaymaker's Avatar
Originally Posted by quick60 View Post
Wow. Seems like a weak link.
Would it hurt to add one?
Originally Posted by SS Tim View Post
Can't see why you think it needs it. The same arangement works fine on C30/400/4-speed trucks with a 10,000gvw.
I was just reading through the thread and immediately thought of my C-30 with the much heavier 4-speed hanging off the bellhousing...and no crossmember!
don
"The DRBMan"
2014 Audi A4 (The Wife's Daily Driver)
2017 HD Ultra (The Cruiser)
2003 HD Fatboy (The Ride)
2001 Chevy Suburban (Another back up!!)
For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!!
dhaymaker is offline   Reply With Quote
