Old 02-03-2013, 10:55 AM   #26
rs74
rs74's Avatar
Re: Wanting to put an overdrive into my 85
I have to look around for an overdrive column too. Maybe if I can find one then they might have a 700 to go along with it. If they had the driveshaft and all then that might make me look going towards the 700.
rs74 is offline   Reply With Quote
Old 02-03-2013, 11:38 AM   #27
dieseltech
At the end of the day it's your truck and ultimatley its your choice what transmission you go with. If you had a 200r4/700r4 sitting in your garage I would go with the 700r4 personally as it is the stronger of the two. But if you have access to an overdrive tranny for cheap then go with that. just make sure its in good working order before you swap it in. there is nothing worse than swapping in a component and have it not work.
Diesel
1986 Chevy Wrangler 4x4
305/700r4
6" lift
37x14.50x15
dieseltech is offline   Reply With Quote
Old 02-04-2013, 11:00 AM   #28
nekkidhillbilly
Originally Posted by dieseltech View Post
Ummm the 700r4 backed alot of vette engines in the late 80's early 90's. had one in my 89 vette. I also have a 700r4 in my 86 k10. 305 with 3.42 gears and 37" tires. the 200r4 came in the overdrive A body cars like the cutlass and regal usually behind a v6 or a really small v8. personally i'd run the 700 over the 200.
im going to stop you right there. the 200-4r came in b bodies (ie lesabre delta 88) and g bodies (ie regal and cutlass). the reason the is the 200-4r has dual bolt pattern the 700 does not. the fastest most powerful american car on the road in the 80s had the 200-4r it was black and had a turbo. in built form the 200-4r is a much stronger trans than the 700. theres those black turbo cars i was talking about are running 9 sec 1/4s with the 200 in built form. the 700 with its deep first gear does have its advantage in a truck for towing purposes but the 200 is def not a weakling at all.
nekkidhillbilly is offline   Reply With Quote
Old 02-04-2013, 11:08 AM   #29
nekkidhillbilly
also the weight compo the electras, olds 98, and the fleetwoods that had the 200 weigh about the same as your truck and had the 307 or 403 olds. in stock form a 200 and 700 are about the same for strength. a built 700 is about maxed at 650 hp a 200 built is around 1000 hp.
Old 02-04-2013, 11:12 AM   #30
Firebirdjones
I prefer the 200 over the 700 if I had a choice. As mentioned, the 2004R's can be made very stout and survive fine in GN's running deep 9's at well over 150 mph.
Personally I like the gear spread on the 200's better. The 2.75 first gear allows for a much closer 2nd gear so you don't have the huge rpm drop associated with the 700 1-2 shift.
Another nice feature of the 200's I didn't see mentioned is that it has slightly more overdrive than the 700. .67 vs .70 if that matters to you.
The uni-bolt bell housing is also nice which makes the 200 a versitile swap in just about anything. Very popular swap with the BOP guys.
Firebirdjones is offline   Reply With Quote
Old 02-04-2013, 11:17 AM   #31
nekkidhillbilly
yeah the only thing i really like on the 700 is that deep first gear helps for truck purposes sometimes like a bulldog gear kinda. a truck is the only thing id prefer one in.
Old 02-04-2013, 11:28 AM   #32
Firebirdjones
Yeah I guess if you run a 2.73 or 3.08 gear and don't want to change that, then the 3.06 first gear in the 700 would work okay. Help give the truck a little more spunk around town.
Old 02-04-2013, 11:39 AM   #33
nekkidhillbilly
id still run a 3:42 or 3:73 even with a 700. i had 01 with the 3:73 and the 4l60e it felt real good pulling trailers and all.
Old 02-08-2013, 03:18 AM   #34
dieseltech
my apologies... you are right... cutlass/regal was a g body not an a body.
305/700r4
6" lift
37x14.50x15
