#26 |
Re: Truck failed emissions
When I worked for Honda, when we had a car that would fail Maryland emissions, a valbe adjustment and an oil change always did the trick (unless the motor was so clapped out, it would never pass). Seems like a lot of unburned fuel can end up in the crankcase and play hell on the numbers.
Probably don't need a valve adjustment, but an oil change- if it's been 'a while'- might help. Posted via Mobile Device
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
#27 | |
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#28 |
![]() Join Date: Jan 2012
You might try looking at the jets in the carb. Might have to rejet. My dad had to do that to get his old Galaxy to pass, but he had a Holley carb. Just my .02
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
#29 |
wow i thought California was bad but I dont have to smog mine at all. 1975 and under I think.
#30 |
Hmmm weird. In Michigan (when i lived there and they had emissions testing) they didnt require it on cars past a certain year since they werent factory built to the current emissions specs. I dont see how they can force you to pass a test that the car wasnt originally meant to pass in the first place. It's like seatbelts. Until it was mandatory and not an option they cannot give you seatbelt tickets for cars that werent originally equipped with them.
#31 |
First off, it sounds like your idle mixture is too rich.
If you're idling at 1000 RPM, you could be pulling fuel from the transition circuit\ primary jets also. Back the idle down to 650-700rpm. To adjust the idle mixture for best emissions, turn each screw in until the idle starts to get rough, back out until it smooths out, then turn each mixture screw back in very slowly until the rpm just starts to drop. For the emission test, you might want to go another 1/8 to 1/4 inch farther in past that point. If you have a vacuum spark advance distributor, unhooking the vacuum line and plugging it during the test may also help.
"Negative people always seem to have a problem for every solution" |
#32 | |
Thanks for the tips, I'll try that.
#33 |
![]() Join Date: Nov 2007
High HC's are mostly problems with ignition components. Since you already have gone through these, I agree with the rich running carb. being the culprit. Also, if you have not already or recently, I would replace the PCV valve...
72 C20 Longbed 05 1500 Z71 |
#34 |
village idiot
Edelbrock carbs are extremely sensitive to dirt and other contaminates in the fuel.
#35 |
That's new also.
#36 | |
Everything seems to work fine other than the emissions though.
