Old 04-06-2013, 10:08 AM   #26
coyotes33
coyotes33's Avatar
Re: Help finding tapping noise.
I haven't checked since the person I bought from asked me not to open it up. In case something major was wrong with it he would swap me engines. I don't know if I want to go through all that since its in already. Would it be better to fix the issue or replace the engine?
coyotes33 is offline   Reply With Quote
Old 04-06-2013, 10:12 AM   #27
85burb
85burb's Avatar
If you have a warrienty on the motor I would see what the seller wants you to do. A cam and lifter swap is most likely close to 900 bucks. The heads have to come off to get lifters out. If they will give you a new motor I would do that. Much faster then a cam lifter swap.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 04-08-2013, 09:38 AM   #28
coyotes33
coyotes33's Avatar
So i ran it without the belt and it still has the same knock, took the covers off as well. I have also been thinking of just going with an aftermarket cam but will see what the seller say's once he gets back to me.
Old 04-08-2013, 10:59 AM   #29
Rufton
One way to locate lifter tick is to slip your friends feeler gauge between valve stem and RA while it's ticking.
Another check is to time how long it takes for all RA to get oil after cold start.
Verify 10 psi per 1000 rpm hot oil pressure.
I would check lifter bore wear on the tickers b4 buying new lifters.
Can disassemble some lifters and check for trash.
Can compare lifter leak down rates on the bench.
Rufton is offline   Reply With Quote
Old 04-09-2013, 11:16 PM   #30
coyotes33
coyotes33's Avatar
I was told to use mystery oil and run the truck for a couple days and see if it helps the lifters. What do you guys think?
Old 04-09-2013, 11:31 PM   #31
85burb
85burb's Avatar
if that is what they want to try befor they give you your money back i would try it. May or may not help. How long have you ran the motor total?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-09-2013, 11:37 PM   #32
coyotes33
coyotes33's Avatar
I haven't driven the truck but I've let it run at least 2 hrs. Oh and the seller started ignoring my calls, got the advice from someone else. I just want to try this before I go knocking his gates down.
Old 04-09-2013, 11:40 PM   #33
85burb
85burb's Avatar
Was it a private seller or a company? Did you buy it with a paypal account?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-09-2013, 11:49 PM   #34
coyotes33
coyotes33's Avatar
Private seller, small town right outside of San Antonio and no pay pal.
Old 04-09-2013, 11:52 PM   #35
85burb
85burb's Avatar
That sucks. I use paypal for all i can. If you ever run in to a issue like this they will help you fix it. I would try the oil and then go visit them.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-10-2013, 11:08 AM   #36
Jon01
Jon01's Avatar
How long did the motor sit for?
Stick a quart or 2 of ATF in it and run it for a while then change the oil.
You can't get lifters out without popping the heads off...
Jon01 is offline   Reply With Quote
Old 04-10-2013, 11:21 AM   #37
coyotes33
coyotes33's Avatar
Since I've had it 6 months. I'm not sure before I got, my guess close to a yr. Should I drive it for a few days?
Old 04-10-2013, 11:25 AM   #38
Jon01
Jon01's Avatar
If it's just lifter tick then I'd stick some ATF in it and drive it a couple hundred miles. If it's going to clean up that oughta do it.
Sometimes after sitting they'll have a hard time pumping back up after being compressed for so long. Varnish builds a ridge inside them and the cup won't go past it.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Old 04-10-2013, 11:32 AM   #39
coyotes33
coyotes33's Avatar
if I start the engine without the valve covers should I be getting a nice flow coming through the push rods or squirting like crazy?
Old 04-10-2013, 11:44 AM   #40
Jon01
Jon01's Avatar
Just a nice flow.
Old 04-10-2013, 11:47 AM   #41
coyotes33
coyotes33's Avatar
Originally Posted by Jon01 View Post
Just a nice flow.
Ok,I got that and oil pressure is around 42 at idle.
Old 04-10-2013, 12:20 PM   #42
Jon01
Jon01's Avatar
Drive it. As long as it's got good oil pressure(which that's very good), you're good to go.
Old 04-10-2013, 02:24 PM   #43
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I fired mine up the other day and for the first few minutes after sitting all year (and a fresh oil change) it taps for a few until the oil warms up and gets everywhere.
I also noticed a louder *tap* this time, and noticed the exhaust gasket blew out at the 02 flange, and the tap was the rythmic exhaust escaping.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-10-2013, 03:42 PM   #44
Rufton
On a quite mild engine, exhaust and lifter noise normally sound very different but on a loud performance engine exhaust leaks can be tricky.
