02-04-2013, 03:24 AM | #26 |
Re: Do you run a fire extinguisher in your truck?
I have a 10 pound extinguisher on my welding truck along with a 2.5 gallon pressurized water extinguisher. I keep a 2.5 pounder in the pickup and suburban too.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
02-04-2013, 09:27 AM | #27 |
This was the suggested location for the GM accessory extinguisher,and where most trucks had them. I mounted one on the roll bar of my Blazer. In trucks with utility beds they get mounted inside the first door behind the cab on driver side. I've mounted on the hump but it gets in the way. I always carry one
02-04-2013, 10:32 AM | #28 |
are you waiting till after to get a fire sale price???
02-04-2013, 08:13 PM | #29 |
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
02-04-2013, 08:15 PM | #30 |
The Niner
Yes, most car shows I go to require them.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
02-04-2013, 09:03 PM | #31 |
Very cheap insurance !!!
02-05-2013, 12:09 PM | #32 |
I carry a Halon or Halotron fire extinguisher in my truck. After cleaning up the mess from normal fire extinguishers I decided to go with this kind since it leaves no residue.
02-05-2013, 12:29 PM | #33 | |
If you've ever had to clean up a dry chemical extinguisher mess, you'll want to get a clean agent extinguisher. Usually the best place to purchase these are from an industrial safety supply house.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
02-05-2013, 12:33 PM | #34 |
Discharge time for halotron is about 10 seconds for bottles 10lbs and under (per Amerex). Dry chemical extinguishers have longer duration the bigger they are (~10 seconds for 2.5lb to ~20 seconds for 10lb). And a 2.5lb halotron bottle is typically only 1/5 the rating for fuel fires as a 2.5lb dry chemical bottle. A 10lb halotron bottle has the same UL(C) rating as a 2.5lb dry chemical bottle. So keep in mind that small halotron extinguisher won't put out any sizable fire, but it will prevent possible damage from the dry chemical itself. You'd probably be able to reliably put out a fire about 12" round x 15" high with that depending on how it's being fed.
You need to periodically shake the extinguishers, especially the powder type. Over time, the powder will compact in the bottom of the extinguisher and if you go to use it, you will get little more than a "pfft" as it clogs. You should be able to hear and feel the powder slide around in the extinguisher as you tip it back and forth. The motion/bouncing/etc of driving makes this problem worse. Last edited by Madtat; 02-05-2013 at 12:40 PM. Reason: add more info |
02-05-2013, 04:04 PM | #35 |
I have one in all my vehicles. In the C10 I made a custom glove box that allows a small Kidde.
02-05-2013, 05:34 PM | #36 |
I am a Referee of life.
Also,keep in mind that fire extenguishers need to be inspected regularly.They do have an expiration date but many can be recharged.Most companies have them in their offices and plants as part of their fire safety program.Insurance companies and the fire marshall require yearly inspection.So if you're carrying one check it and if you're buying one check to see what the shelf life is.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-05-2013, 05:44 PM | #37 |
Mine was on the driver side on the buddy seat frame on my 67. i am assuming this was put on by the dealer. I have a original recharge kit for it as well but am unsure if i will charge it. may be too old. I Might hide another one somewhere in the truck that is newer and probably better.
02-05-2013, 06:08 PM | #38 |
Right now mine is rolling around the passenger side floor. I've been trying to come up with a good place to put it that won't be in the way, but I just haven't thought of one yet. I like the idea of tucking it in the cubby by the passenger seat, but in an emergency that would take a while to get to...
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
02-05-2013, 07:16 PM | #39 |
I have mine mounted behind the seat of my Jimmy not sure if it would work on the trucks with the gas tank behind the seats though
02-05-2013, 09:59 PM | #40 |
It would fit on the paasage side I think, but thats not the best place if your in a hurry.
02-05-2013, 11:01 PM | #41 |
Needs to be visible.If someone else is grabbing for one,they should be able to find it.
02-05-2013, 11:57 PM | #42 |
Wonder if a bracket under the glovebox would work? I don't have AC...
02-06-2013, 12:48 AM | #43 |
Good point about the difference in fire suppression on similar size extinguishers. Below are examples of Ansul 2.5lb stored pressure extinguishers. The clean agent has a 2-B:C rating meaning, a novice should be able to put out a 2 foot square fire. The other is a dry chemical extinguisher about the same size that will put out a 10 foot square fire in the hands of a novice. With training you should be able to at least double this number.
I sold safety/fire equipment for about 25 years and was trained at the Ansul training school in Wisconsin. The thing to remember when putting out an engine fire is too bump the extinguisher and not just open it up and dump it. Engines can be very hot and have a tendency to re-ignite fuel. By bumping it you are buying time to hopefully let the engine/exhaust cool below ignition temp. Also, don't buy cheap. You really do get what you pay for with these extinguishers if you know what you're looking for. For example many of these extinguishers have plastic heads. Look for metal heads, also a short nozzle hose is a good thing, it gives you more control. Lastly, the cost difference between the two listed below are about $150 at retail. $195 vs $50. But do you really want to shoot dry chemical down your shiny new carb? Not me. After you shoot a clean agent, it's simply gone. No clean up. Item #: 09626 2.5 lb FE-36 CleanGuard Fire Extinguisher w/ Vehicle Bracket 2-B:C rating Item #: 09601 2.5 lb Ansul Sentry Foray ABC Dry Chemical Fire Extinguisher w/ vehicle bracket 1-A:10-B:C rating
02-06-2013, 06:48 AM | #44 |
I really need a coulpe too. I have a cheap one in the Talon but I bet it has set up by now.
1972 Custom 10 Deluxe- original paint, interior- 72k miles http://www.cardomain.com/ride/2466316 Cheap, Fast or Good. Pick any two. 1990 Eagle Talon AWD 1991.5 W250 CTD 1992 Cushman Truckster- Haulster |
11-01-2014, 01:25 AM | #45 |
I'm bumping this thread.
I want to get me a Halon 1211 and not the DryChem. The thought of getting that stuff into crevices would make me loose sleep. Would Halon be effective in a bad scenario and how much (Extinguisher size) would one need? 2.5lb is a nice size space-wise, but effective? Has anyone here actually used a Halon 1211 Extinguisher on an engine/vehicle fire before? |
11-01-2014, 03:02 AM | #46 |
Had one mounted to the heater box, used small screws. Looked great and was out of the way. You could also wrap one up (in cloth etc) and place in the passenger side corner behind the seat where the jack goes. Get a C02 one as dry chem will wreck your engine if you have a fire and it gets into the carb.
11-01-2014, 01:33 PM | #47 |
I pack one in my glove box. It probably should be more accessible. I like the idea of the ps kick panel that somebody here showed.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
11-01-2014, 10:38 PM | #48 |
Carpe manana
Mine in the 72 K1500 is uncharged - that probably makes 30 years or so in a row now. Time for a new one - it would be great if I could reuse the existing one.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
11-02-2014, 12:14 AM | #49 | |
FYI, for those of you looking for quality hand held extinguishers, Ansul & General are probably two of the better brands. I personally prefer Ansul. Also, you should look at Safety Supply distributors for the better equipment and pricing. I'm out of the business but would be happy to recommend some national companies if you drop me a PM.
11-02-2014, 12:31 AM | #50 |
RAT1968 '68 Cab/'71 Parts
I'll have to check what type this one is. It's pretty new.
And, every once-and-a-while, I pull it off of the floor and out of the bracket for "quick draw" practice.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
