Old 02-11-2013, 10:15 PM   #26
Andy4639
Old member
Andy4639's Avatar
Wink Re: New Exterior Lights / LEDs
Well not 100% sure but the rear side markers shouldn't blink with the fronts unless some one has rewired them. I also have the LED's with diamond cut reflectors in the lens.
The camera makes it look amber when it's on but it's red!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-19-2013, 04:51 AM   #27
JointTech
JointTech's Avatar
well to finish this thread up... I just got a chance to get a picture of the reverse lights and test them at night. Bright!!
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 05-28-2013, 05:35 AM   #28
mcmlxix
Collector of Projects
mcmlxix's Avatar
Bringing this back up to the top... Does anyone know what board vendors sell the deluxe marker lights? I would rather support a board vendor then not, provided the cost isn't out of sorts.. So far I found the United Pacific brand with stainless deluxe trim for $27.95 each...
Rich
1972 K5 Blazer CST Click HERE
Old 11-13-2013, 10:37 PM   #29
Mayo
Cool Truck
Mayo's Avatar
I have been thinking about upgrading to all LEDs, already have the tail lights just not installed yet, and I noticed you said the sidemarkers got hardwired. Are these the ones from LMC? Brothers lists LED sidemarkers that are plug and play although the picture looks like a standard lense. Has anyone gotten these ones yet?
http://www.brotherstrucks.com/prodin...=SMLD72R&qty=2
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 11-13-2013, 10:42 PM   #30
JointTech
JointTech's Avatar
mine came from LMC. Even the brothers picture you linked shows wires not a plug. they aren't plug and play. there will be splicing.
72 C20 Long Bed
Old 11-14-2013, 02:59 AM   #31
mcmlxix
mcmlxix's Avatar
They are produced by United Pacific. The tail lights have the correct connector but the front and rear SIDE lights do not have connectors. The amber lights on the 68-72 are dual function from the factory but the red rears are not. I believe the front anmber turn lights have the connector, but I havent seen them in person. I heard they will be making some clear 69/70 front LED grill signal lights but they offer the yellow lense ones now.
http://www.uapac.com/antique/lightin...de-marker.html
Rich
Old 11-14-2013, 07:59 AM   #32
Andy4639
Old member
Andy4639's Avatar
Originally Posted by Square_78 View Post
My rear side markers blink with the turn signals. Is this not standard??
The rear side markers have no reason to blink. Stock rear side markers didn't blink.
Old 11-14-2013, 06:58 PM   #33
Mayo
Cool Truck
Mayo's Avatar
Thanks for the info, I wish I could find a plug in set.
Old 11-16-2013, 02:37 AM   #34
mcmlxix
mcmlxix's Avatar
google or eBay a 1156 or 1157 male adapter .... solder and heat shrink and they're plug and play...
http://www.ebay.com/itm/1157-TAILLIG...-/390545428100
Rich
Old 11-16-2013, 03:59 PM   #35
Andy4639
Old member
Andy4639's Avatar
Here are mine. Brakes,front turn signal's and side markers.Yes I had to swap in the flasher with ground wire to get them to work.
Bought the LED bulbs at O-Riellys.
Old 11-16-2013, 04:04 PM   #36
Andy4639
Old member
Andy4639's Avatar
Front turn signals.
Old 11-17-2013, 11:43 AM   #37
Mayo
Cool Truck
Mayo's Avatar
Thanks for the link but I was looking for side markers that plug in. They use a different socket seeing as they are 194 bulbs.
Old 11-17-2013, 04:51 PM   #38
mcmlxix
mcmlxix's Avatar
oops.. wrong adapter.... the T10 type adapter is available as well ... with a built in load resistor.... HERE
Rich
Old 11-17-2013, 05:01 PM   #39
HotRod C/10
HotRod C/10's Avatar
http://www.ddmtuning.com/Product-Cat...-CLUSTER-BULBS
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 11-17-2013, 07:47 PM   #40
Mayo
Cool Truck
Mayo's Avatar
thanks for the link
Old 11-17-2013, 08:09 PM   #41
Tinkermc
Soldering upside suuuuucks, you need more practice. Do it right.
Tinkermc is offline   Reply With Quote
Old 03-21-2014, 08:13 PM   #42
Mayo
Cool Truck
Mayo's Avatar
JointTech, would you mind posting a pic of the wires you tapped into up front? I was trying to wire mine into a plug by wiring the running and turn signal wires together but when I do that they don't blink unless the running lights are on and they don't use the brighter leds.
Old 03-21-2014, 08:18 PM   #43
JointTech
JointTech's Avatar
sorry I started over. Took my cab and bed off and the frame is going to the blaster this weekend. Let me see if I can find any old pics
72 C20 Long Bed
Old 03-21-2014, 08:23 PM   #44
JointTech
JointTech's Avatar
sorry I wasn't as pic happy back then. I just looked in my build thread and realized I just copied what was in this thread...
72 C20 Long Bed
Old 03-22-2014, 09:45 AM   #45
Mayo
Cool Truck
Mayo's Avatar
Ok, thanks for the info
Old 10-04-2014, 06:59 AM   #46
rc32187
rc32187's Avatar
I've been thinking about swapping my front signals to the clear lense plug n play led style on my 67. What needs to be done to keep them from hyperflashing? Do I need the 2 prong flashers with the ground wire? Thanks Sorry to bump an old thread, but I didn't think it was necessary to start a new one.
rc32187 is offline   Reply With Quote
Old 10-04-2014, 07:15 PM   #47
full foot notch
A neat one I've been looking at is a "1157 led switchback " if looking on ebay , run about $35 and white when parking light and alternates between proper orange and white when flashing.
full foot notch is offline   Reply With Quote
Old 10-09-2014, 01:23 PM   #48
Mayo
Cool Truck
Mayo's Avatar
Yeah a flasher with a ground wire is all you should need
Old 10-09-2014, 01:33 PM   #49
hdff
hdff's Avatar
Found the problem with my backup lights. I looked at the neutral safety switch and first thing I saw was the 2 purple wires were jumpered not on the switch. The backup lights were still plugged in but I got no conductivity between the to connectors at any gear selector position. I pulled it off and the thing is crusty. Barely moves by hand and sounds grindy.
My small parts house doesnt work on weekends and it would be monday before they have one so I went to crap boys and ordered one to be here tomorrow for $11.
Hopefully that fixes it at which point all my exterior lights will be working.
could you take a pic of the wires on the nss. mine is not hooked up and i don't even see any wires to hook up. maybe if i see what i am looking for it will pop out at me.......................
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
