02-08-2013, 01:11 PM | #26 | |
67-72 parts collector,…
Re: Conversion axles $158.56 to my door?
I assume they are stock replacement axles for a 71-72 truck. My only concern is if they are "NEW" axles,... or reconditioned used axles. Moser axles will be new.
02-08-2013, 02:05 PM | #27 |
A day late and $1 short...
As far as I know these are new axles built by Motive Gear. I just recieved the tracking number and it looks like we will have all the answers on Tuesday evening.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
02-08-2013, 02:07 PM | #28 |
I think this is my next step, how much work is swapping the rear axles? I have already finished the disc upgrade up front (Thanks Keith!)
In my opinion, it works best to have the seat out so you have room to flop your body around while standing on your head. -ashx2 |
02-08-2013, 03:10 PM | #29 |
Sweet. Thanks for the info Guys and Buck for posting this thread.
Posted via Mobile Device |
02-08-2013, 03:39 PM | #30 |
Looks like zero available for the shorter 30.5 axle
02-08-2013, 03:50 PM | #31 | |
http://www.customclassictrucks.com/t...e/viewall.html
02-08-2013, 04:29 PM | #32 |
Dorian, it's easy really. The biggest thing to look out for is the pin / bolt that holds them in place. Go ahead and plan on it breaking when you take it out. Most of them do.
Realizing this is not a typical carrier you'd see in your truck, this will give you an idea of how to get the bolt out. I have one of these extractor kits. If yours breaks and you want to borrow it, you're welcome to it. I think they're ~$40 to buy and you get a new bolt. Great Article Keith.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
02-12-2013, 11:10 PM | #33 |
Here is a picture of one of the axles. They look to be slightly nicer than stock, which is fine for my old farm truck.
Chad, they didn't come with studs, my CPP brake kit will have them, so no measurement, sorry. Seems to me, when I compare them to the axles I received from ECE that these are comparable if not a little nicer (appearing). Once I receive my CPP disc brake kit, get the rear end installed, and take it for a ride I will give a final review. But so far they look to have been a pretty good deal. It's too bad they don't sell them for the short rear axle.
02-12-2013, 11:16 PM | #34 |
Cool. If these work out I'll be picking up a set for my truck. "fingers crossed"
02-13-2013, 12:12 AM | #35 |
subd
04-01-2013, 01:27 PM | #36 |
So for a 1968 stock 5x5 lug conversion I would need the axles listed at this link, correct?
http://shop.advanceautoparts.com/web...-gear_99985987 Getting ready to order the parts if so. Got to get this thing on the road again
04-01-2013, 01:39 PM | #37 |
Hey dorian, if you look closely at the description of the item in the link you provided, they are replacement 6 Lug axles. The ones Buck and I ordered were 5 lug and for the longer 70-72 rear end. He swapped out his original read end for the wider one to clear up some wheel fitment issues with his custom wheels. I don't think Motive Gear makes the shorter axles in 5 Lug.
04-01-2013, 01:41 PM | #38 |
Crap, thanks! too excited to pay attention
Would this work ya think? http://www.summitracing.com/parts/ms...gmt5/overview/
04-01-2013, 01:56 PM | #39 |
Looks like it should. I'm still pretty new to all this. I do know that Chad "CC69Rat" used Moser axles to do his swap.
04-01-2013, 02:03 PM | #40 |
Use Dorman wheel studs, part number 610-298.1
1/2 x 20. These are for the longer 70+ rear end housing. 31 5/16 long from the end of the splines to the mounting surface of the axle. ( where the wheel makes contact) The earlier axles are 30 1/2 in long at this same point Posted via Mobile Device
04-09-2013, 07:31 PM | #41 |
For the short 67-69 rear end, not as inexpensive as the long rear end axles but not a bad price, $116.95 ea.
http://www.summitracing.com/parts/sag-pa6068
04-23-2015, 11:05 AM | #42 |
Trying to order another set of these axles, looks like it was a one-time good deal.
04-23-2015, 12:10 PM | #43 |
Not as good of a price as the Summit or Moser, but Advance does offer the shorter axles in 5 lug. If you sign up for the the Advance "Speed Perks" program, they are regularly offering coupons.
States on their site under the "Description" tab: Product Features: AXLE SHAFT 65-69 12 BOLT 8 7/8 30 1/2" 2 & 4WD 6 LUG TO 5 LUG CONV http://shop.advanceautoparts.com/p/m...d=1#fragment-2 Also, if you select the "specifications" tab, this is what you see: |
04-23-2015, 12:50 PM | #44 |
im looking for 1970 shafts for my c10 to convert it to 5 lug. Between moser, motive, alloy, dorman, etc... they all have conflicting information on the lengths of the shafts. It seems people say 2wd is 31-5/16 and 4wd is 31-9/32 for the lengths
search on Motive Gears site for a 2wd truck and you get results for 31-9/32 (.2812) GM part number 14017151. Do a search for 4wd and you get results for 31-5/16 (.3125) GM part number 14017150. Which seems backwards. search mosers catalog and you get 70-81 2wd is 31-5/16 5 lug and 4wd is 31-9/32 6 lug. Which seems right. Search superior axles and you get 2wd 14071751 31-5/16" and 4wd is 14071750 31-9/32" Search for 2wd on advance auto’s page and you get motive’s 31.28125” length says fits 2wd gm part number 14071751. Click dormans from the advance site and its part number 630-128 and if you search that on dormans site it says its 31.35” (close to 5/16”) Pro-king’s catalog says the AX-183 is the 5/16 and AX-182 is the 9/32 which seems right. Basically if someone can definitively confirm that the 5/16” is the right length for a 2wd axle, I can just ignore the suggested fitment crap from all the websites and get the shafts as per the companies length listing (except motive’s they seem backwards right on their own website which I think is what threw off all the dealers sites) I would measure it myself but I just bought the truck and don’t even have it in my garage yet, I am stocking up on parts for when it gets here. |
