Old 02-15-2013, 07:58 PM   #26
Gumby
Gumby's Avatar
Re: oil change ?
^ RP trans fluid is a PITA to read on a stick it has so little color to it, other wise good stuff. [$80 5gal jug from summit but ill use redline next time for the standard red color]
Chevy GMC Trucks Find Of The Day
https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com
Gumby is offline   Reply With Quote
Old 02-15-2013, 08:01 PM   #27
Transformula
Transformula's Avatar
Re: oil change ?
Originally Posted by richards72chevy View Post
Ive been using the ph5 for last 12 years on my 350.I may be using the wrong one.Lol.I thought the ph30 may be a heavy duty filter that held more oil.
The Fram PH5 has an anti-drain back valve in it, the 30 does not.
T.Y.N Custom Works..... Because "Stock" Sucks!
1971 K 10 GMC Long Bed
1977 Formula T/A Frame off Resto-Mod
1995 FXDL Harley Low Rider
1985 C10 ShortWide 91 Burb front.
Transformula is offline   Reply With Quote
Old 02-16-2013, 12:12 AM   #28
richards72chevy
richards72chevy's Avatar
Re: oil change ?
So the ph5 is better than the ph30?
richards72chevy is offline   Reply With Quote
Old 02-16-2013, 12:24 AM   #29
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: oil change ?
If your filter sits upright like mine does, it's always full of oil anyway.... I don't see how an anti-drainback valve would make any difference.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-16-2013, 01:18 AM   #30
oklalawnboy
oklalawnboy's Avatar
Re: oil change ?
Brad penn is the way to go in older automobiles. It still has enough zinc to lubricate the older engines properly. The newer oil (any brand) is made for newer cars (80- up) with tighter tolerances/better bearing etc. my 2 cents
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 02-16-2013, 02:11 AM   #31
Gumby
Gumby's Avatar
Re: oil change ?
rash of new break in oil is the loop hole around that, they just make oil the good way, say its only for a one time use to make the EPA happy and wink wink nod nod, you can use it all the time just don't ask, don't tell
