#26 | |
Re: Rearend swap
ron |
#27 |
Re: Rearend swap
Thanks Captainfab for the explanation
#28 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Rearend swap
Here are a couple pics with measurements, of a GM truck 12 bolt 3 series carrier (3.42 gears and higher). It's hard to tell with the camera angle in the 3rd pic, but the measurement to the center of the center pin hole is 2". I didn't have a 4 series carrier out of a housing. I'll see if I have time to do that tomorrow. The 4 series carrier has the ring gear flange closer to the center pin.
#29 |
Re: Rearend swap
Why did no one happen to say i will/ may need the mounts and u-bolt from the 85 to mount the rear end back under my truck? I got the old one out slide the new one under it and now i cant go any further because i can not use my old bolts and mounts. I hope when my friend calls me back he has some laying around.
Sorry just blowing off steam! Posted via Mobile Device
1964 ![]() |
