Old 02-15-2013, 06:29 PM   #26
ls1nova71
ls1nova71's Avatar
Re: driveshaft angle with pix
Originally Posted by Tom Vogel View Post
Also, that driveshaft ought to be into that tranny about 2 1/2" further.
I agree, your driveshaft looks a little short. How long is that tailshaft? If it's too short, you'll tear up the bushing in the tailshaft and then have other things to worry about.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-15-2013, 06:41 PM   #27
brad_man_72
the boat guy
brad_man_72's Avatar
Originally Posted by CC69Rat View Post
Just to add something else for you.. read through this kit writeup. It will make it all make more sense (it did for me) I know this is S10 stuff, but I promise I used this kit on my 96 S10 ext cab it has ZERO vibration in it anywhere. It is smoother now than it was from the factory. I'm sure the same concept applies to our C10s.
http://www.jagsthatrun.com/Pages/Par...aft-Align.html
Extended cab 2wd s10s are notorious for eating the rear double cardain joint, especially if lowered. The pinion angle is off from the factory. We won't warranty an ex cab 2wd s10 shaft unless they shim the pinion down.
I rebuild at least 3 a week.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
