#26 |
Re: 65 3 on the tree with over drive ?'s
Southern, you can still shift without the clutch into first if the overdrive cable is in. is that correct?
#27 |
Ok nice, so no floating gears. How strong are the old Muncies can that take above 350-400HP&TQ. I'm not trying to set records. I just want something fun with a lot of cool to drive around.
#28 |
Southern, you can still shift down without the clutch if the overdrive cable is in. is that correct?
#29 |
So Lee with 3 sp. is in your truck now. the Muncie or the saginaw
#30 |
Wrench Wench
![]() Join Date: Apr 2008
No you can't shift to 1st without clutch and being at an almost dead stop, and I'm pushing mine with a standard build 70's 350, and it has enough a$$ to impress the teenagers :-) I drive 40 miles round trip 3 -4 times a week 55-65 mph, and it is still smooth shifting. Long run I don't know how it will hold up, but so far so good.
If everyone had good taste, who would buy all the FORDS? ![]() Women join us!! BUSTED KNUCKLE BABES ![]() "Face it girls, I'm older and have better insurance" -Fried green tomatoes |
#31 |
Nice I have a 3spd sag in my truck and an m21 in my garage. no synchro 1st in my 3spd so I can float no clutch 2nd to 3rd not 1st to 2nd. Idk about the m21 I should since it's full synchro
#32 | |
![]() Quote:
I've done the above using it with a 327/250hp--hopped up--and worked like a charm. Lotsa fun! Just don't look for speed-shifting unless od is locked out via cable; then it's just like a normal, not so strong factory 3-speed. ![]() ![]() Sam |
#33 |
Wrench Wench
Thanks luv, I have seen the wiring diagram for that set up. When I installed it I was just trying to get it on the road and saving the "fun" stuff till I can install a new rear axle. Not sure the original on it now could take the abuse I would be forced to give it!!
#34 | |
#35 |
Southern907, You should be able to shift between 2nd and 1st without the clutch as long as your under the magic mph 25 or 28? that's the cool thing about the Borg warner O/D. it doesn't matter which tranny you have. it's the freewheel clutch in the overdrive that lets ya go clutchless. but it has disengage the sol. I have the overdrive behind the 4 sp. but it worked the same way with the 3 speed. if I turn the switch off with the cable still in overdrive I can take the tranny from high gear to 1st without the clutch easy but ya got no engine brakeing. and as soon as ya rev it up enough for the engine to caught up away ya go. Am I right guys & gals ?
#36 | |
Thats an R10 overdrive right? |
#37 |
Wrench Wench
Frankslagoon, yes mine should work that way, however I am going to have to replace my speedo gears internally.....I'm 15mph slow on my speedo, so I actually have to get up to 40 for my od to kick in, so it throws shifting off just a little too.
#38 | |
#39 |
Southern maybe your gov. is gummed up. the governor doesn't care what the speedo says or if it's even hooked up. the gov. is driven off the drive gear on the output shaft inside the tail housing the speedo gear to the dash rides on that gear also but doesn,t have anything to do with the o/d gov. I'm pretty sure bowtie is runnin power to the sol. not the gov. ?
#40 |
I'm taking a lot of notes haha
#41 |
Yes its a R10 the R11s r hard to find they have 4 gear pinion gear ass. instead of 3. You have drill a hole in the 4 speed case for the reverse lock out rod to come thru. ya can,t shift into reverse while in overdrive or you'll kill the engine. the o/d trannys have a bump on the reverse shifter inside the tranny that pushes a rod back into the o/d and shifts out of o/d when ya shift into reverse. But I'm thinkin the cases might be the same and ya could actually use the 3 speed case. maybe,
#42 |
#43 |
IF you clip the gov. spring you can get OD in first and if you make a shift knob with a kick-down switch in it you can shift first let off the gas first/over then shift to second push the button ....now in second let off the gas and now in second/over .....shift to third push the button now in third let off gas and third over ...MY dad did this on a top load 3 speed years ago
#44 | |
#45 |
I would kinda like to get the gov. hooked up cuase I have a habit of leaven it switched on and starten out in o/d 1st gear. which isn't a good idea.
#46 |
what you have done is bypassed the gov.- relay and kick down switches.... You do pull the cable out when parked???? is the solenoid power on ing. switched or acc.? so when you shut the truck off there is no power to the solenoid?
#47 |
That's what I did . I ran a wire from fuse blk. that comes on when I turn the key on. then up to a switch on my shifter. then down to the sol. the switch is a 30 amp push -pull and so far it's hangen in there?? but my problem is the relay. All the old relays look like a 3 prong relay.I think the power should go from the batt. or ign. to the relay and thru the relay to the sol. the gov. must finish the circuit by grounding the relay ? is that right. ?
#48 |
I usually leave the cable in overdrive and always put the trk in reverse putten it in reverse is the same as pullen the cable out
#49 |
To bad we are so far apart I have one of the non syncro o/d that would slid right into your trk. like Southerns. I'd make ya a good deal on. I bet you could find one arfe you in texas or Cal. that's the one that your linkage would fit.
#50 |
I am in tx I need to update that. I just got out of the Corps, and I would spend half my time in tx and half in Cali.
