03-01-2013, 01:17 AM | #26 |
Re: Garage heater
If we only still had our pool up, that would of been a good idea. tried heating it once using the filter to pump the water through a car rad over a fire, bad wood or something as it just clogged the fins with smoke resin of sorts aka didn't work long.
03-01-2013, 01:20 AM | #27 |
Re: Garage heater
Agreed. Electric is 'more efficient' (nearly 100% of the energy is converted to heat) however the price of electricity is not cheap. Not out here anyways (calif)
We had neighbors that replaced their nat. gas water heater with an electric only to replace it again with gas after their electric bill came 30 days later. |
03-01-2013, 01:24 AM | #28 | |
Re: Garage heater
For our Softub (hot tub with no real heater) I use this portable propane water heaterWorks very well. Going to set this up for the horse trailer too for showers on the road. |
03-01-2013, 07:20 PM | #29 |
Re: Garage heater
I'm thinking of using this idea but maybe just large coil of copper tubing instead of radiator. Still work the same?
72 GMC super custom. |
03-01-2013, 08:38 PM | #30 |
402 BIG BLOCK
Re: Garage heater
It would work, but the more surface contact area the better. Plus a used radiator you could get cheap. Either way let us know how it works.
1967 C10 swb 1970 GMC Jimmy 4x4 2005 Chevy tahoe Z71 2001 Chevy impala |
03-01-2013, 08:40 PM | #31 |
402 BIG BLOCK
Re: Garage heater
We sure have a lot of iowa members on this post. Not that iowa isnt the best or anything.
03-01-2013, 09:25 PM | #32 |
Re: Garage heater
Well I need a garage door first no sence heating an open space lol
03-01-2013, 09:42 PM | #33 |
I am a Referee of life.
Re: Garage heater
CAUTION!!! if you use a gas water heater,there is either a pilot light or a spark ignitor.If you are using it in a garage,keep the fuel out. A spilled gas can or small fuel leak could rapidly become a full fledged fire.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-01-2013, 09:44 PM | #34 |
Re: Garage heater
Very true^
03-01-2013, 10:18 PM | #35 |
Re: Garage heater
Not so the new water heaters have a vapor screen that keeps it explosion proof. Code says you keep the bottom of the water heater at least eighteen inches above the garage floor. this is a federal code for all fifty states. The water heaters were changed because in the warmer states the water heaters are in a closet in garage.
03-02-2013, 08:07 AM | #36 |
1969 Custom 30 wrecker
Re: Garage heater
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
03-02-2013, 04:02 PM | #37 |
Re: Garage heater
Ya but at least you turn a nice shade of red.
03-02-2013, 11:02 PM | #38 | |
Re: Garage heater
nobody ever intenionally spills gas on the floor it just happens sometimes and those fumes they will travel across the floor and whooof! fried grease monkey around her alot of guys have the moblie home furnaces in there garages. I gotta find one someday
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
03-02-2013, 11:18 PM | #39 | |
Hand Crafted C-10
Re: Garage heater
BTW-a good source for free or nearly free squirrel cages is the oil and gas furnace installation companies. Often old furnaces are pulled and given to the scrap man. Most of those guys are quite happy to get above scrap value. . |
03-03-2013, 12:30 PM | #40 |
Re: Garage heater
Clever. Similar in principle to hot water baseboard.
My father had an attached single bay garage. Inside, the PO of the house, had installed an enclosed radiator from a school and tied it in to the hot water baseboard system of the house. 2 valves to isolate the rad and a drain valve on it, so it could be drained and not freeze up. For quicker warm up, a small fan blowing through the radiator. He used it for his woodworking, kinda nice to walk into a 50-60 degree shop when it's snowing outside. If need be, stuff could be moved and he could still get a car in there.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
