#26 | |
Re: Pic of charcoal canister
#27 |
![]() Join Date: Jul 2001
Is this one correct? And has anyone used one? Thanks, Ray Posted via Mobile Device
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
#28 |
![]() Join Date: Dec 2011
The one I bought with that same part number was 6 or 7 years ago and I paid almost a hundred for it. I also assumed that it had been discontinued so I was surprised to see it available at this price. The only difference cosmetically is the purge valve has a very slightly different cap but all the ports are the same and the manufacturers logo is even the same.
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350 1971 K-10 Custom Deluxe 1971 K-10 Custom |
#29 |
Vintage 4x4s
I wonder if you could open the old one and replace the charcoal media?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#30 | |
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#31 | |
#32 |
Me too, you can see in there from the bottom, I wonder if the top comes a lose some way?
#33 |
If you download the service manual for your particular year it will be listed as the "Evaporation Control System". For '71 C-10 everything is around pages 8-8 through 8-10. There are procedures for removal but it's pretty easy to figure out once you figure out the entire bracket can come off. The $3 filter that can be bought at any parts store looks like it's just a filter to keep things out of the canister. When I pulled out that filter the carbon started coming out. It looked like there was a very thin sheet of foam that was used to keep the carbon in when it was new but over 40+ years that had rotted away. So now I have an empty canister that I plan on dumping fish carbon in and putting back together. The canister does do something. My garbage smells like exhaust now.
#34 | |
#35 |
As far as the canister goes, none that I'm aware of
#36 |
![]() Join Date: Jun 2013
I bought a new '73 and it had the canister.
Gale Gorman '54 3100 '67 C20 stepside |
#37 |
Is this part really necessary or can you do without it?
I have 72 K5 and it doesn't require to be smog checks. I started pulling everything out because I'm putting in a fresh motor in so I'm starting to put together a parts list for replacing fuel and brakes lines with stainless steel. I'd rather not use it if you don't need. Plus it's one less stainless steel fuel line I would need to buy
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
#38 |
One of my '71 K10's canisters had been removed by a PO and it ran fine but I noticed fuel odor every time I was under the hood. It was then that I realized that it was missing and put one in and the odor was gone.
