Old 03-06-2013, 05:58 PM   #26
Hardesty454
Hardesty454's Avatar
Re: T1I08TLM - Can you decode this!?
That's what I thought, but it looked like an I. Another reason I ask you guys, more knowledge than I could obtain!
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 03-06-2013, 06:01 PM   #27
chevyman91
at is the date code on the front passenger side pad
chevyman91 is offline   Reply With Quote
Old 03-06-2013, 06:03 PM   #28
chevyman91
That is the date code
Old 03-06-2013, 06:18 PM   #29
Hardesty454
Oh........ I knew that. Hahaha
Rob
Old 03-06-2013, 06:53 PM   #30
chevyman91
No worries. Glad I could help you after I got the suffix code right
Old 03-06-2013, 07:39 PM   #31
SS Tim
SS Tim's Avatar
There are six points of information (most of the time) on 67-72 truck V-8 blocks both big and small.
Engine code on the machined block deck pad, in this case stamped T1I08TLM which is a misstamp. Being that the stamps were individual letters and numerals placed in a gang holder for striking, this is not uncommon substitution. The engine code gives use three points of information, the engine assembly plant, the engine build date and the specific application it was built for. In this case Tonawanda, November 08th, 71-72 Truck L47 402/210 C10-20 w/AR (air injection) with a TH400
Casting number is cast into the block, in this case 3999290 and it identifies the casting but not always the application it was finish machined for or assembled as. This number could have been a 68-69 truck 396 or a 70-72 car or truck 402 in addition to 2 or 4 bolt variations.
Casting date gives the rough date in a month by letter, numeric date and last digit of year. Examples for this motor might be J010 or K281.
Casting clock (circle of dots and an arrow) breaks down the date by hour and shift the block casting date. This is mostly only useful for production reasons.
SS Tim is offline   Reply With Quote
Old 03-06-2013, 07:44 PM   #32
chevyman91
I have heard that its not uncommon for them to exchange an I or L for a 1 but don't know how much truth there is to this
Old 03-06-2013, 11:02 PM   #33
bruceman1968
bruceman1968's Avatar
Originally Posted by Hardesty454 View Post
Could swear that's an I.
That is a I, it's a miss stamp, should be a 1. On the bright side, no need to get your eyes checked. If you have the protect-o-plate, that code will be on it. T1108TLM. Did you get the date code? It is a cast into the block.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 03-06-2013, 11:34 PM   #34
Hardesty454
No I didn't grab the date code. I can!
So all in all, the block is essentially what came with this truck... I kept imaging this was something done throughout the years.
Rob
Old 03-06-2013, 11:45 PM   #35
bruceman1968
Yes, get the date code if you can. That way we'll know for sure that it's a 71. This is all good news for you, Original motor is a plus, and the 71 had 310hp the 72 had 210hp.
Old 03-07-2013, 12:31 AM   #36
Hardesty454
J29 71
Jan 29 of 1971?!?
Rob
Old 03-07-2013, 12:39 AM   #37
bruceman1968
J is October, The block was cast on oct. 29 1971. It was assembled on nov. 8th, 1971.
Old 03-07-2013, 12:55 AM   #38
SS Tim
SS Tim's Avatar
If your truck is a RPO L47 truck (400 CID) and the door sticker (the blue cert. label) has 11/71 in the top right corner it may very well be the original block.
Old 03-07-2013, 01:03 AM   #39
Hardesty454
I do not have a door sticker
Rob
Old 03-07-2013, 01:28 AM   #40
SS Tim
SS Tim's Avatar
If you want PM me the VIN and I will try to match it with known build date trucks. This is a longshot as I need VIN and build dates close from the same plant to be anymore than a guess. It would still be a guess but not a WAG.
Old 03-07-2013, 01:32 AM   #41
Hardesty454
I ran my VIN and it came up with the Fremont plant. However this motor is from NY. Is that common for them to be made separately?
Rob
Old 03-07-2013, 01:39 AM   #42
SS Tim
SS Tim's Avatar
Yes the engines were shipped to Fremont for final dressing then line installation. Your truck may be a December 71 build. Is there a build sheet in the seat back? Do you have the protect-o-plate?
