Old 03-17-2013, 04:28 PM   #26
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Powering my 84 C10
Originally Posted by coyotes33 View Post
Ok i have everything hooked up. I have constant 12v to the relay and 12v to the ignition on/cranking. My fuel pump is not turning on so the injectors aren't spraying and it does turn over. I have checked all my connections, what else can i do to check that the pcm is turning on?
Put an obd scanner on it and see if it registers anything (even key on should show power).....and before you do that hook a hot 12v from anything (even just straight off a battery) to the PUMP and make sure they fuel pump wasn't DOA. By far the most common dead part out of the box is a fuel pump.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-17-2013, 04:34 PM   #27
coyotes33
coyotes33's Avatar
I did put 12v straight to the wire that goes to the sending unit and the pump turns on.
B][/B]
coyotes33 is offline   Reply With Quote
Old 03-17-2013, 06:55 PM   #28
coyotes33
coyotes33's Avatar
Got it all figured out. Thanks to all of you that help me out. Im not completely done so im sure ill be asking more questions
https://www.youtube.com/watch?v=cgk-...e_gdata_player
Old 03-18-2013, 09:04 AM   #29
mej005
Congrats. What eneded up being the reason you were not getting power to the fuel pump?
mej005 is offline   Reply With Quote
Old 03-18-2013, 09:09 AM   #30
coyotes33
coyotes33's Avatar
User error, i had a terminal grounded that needed to go to the starter.
