03-13-2013, 09:03 PM | #26 | |
Re: My first Restoration...Where to start?
Like pices of frame, wayward crossmembers, ECT. |
03-13-2013, 09:11 PM | #27 | |
Well If you shoot the 44 you may need another car to pick you up in the next county! |
03-13-2013, 09:25 PM | #28 |
I just shot that gun this evening at a local gun place, once was enough! I'll stick with my little Walther ppks!
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
03-13-2013, 09:36 PM | #29 |
I havent shot mine for a long time
03-13-2013, 09:53 PM | #30 |
You can first start by cutting that tree down thats growing out of the engine compartment!
1955 GMC Hydramatic 1959 Chevy Spartan 100 1969 Chevy C/10 1969 Chevy C/30 Bruiser 1972 GMC (Wrecked) 1972 GMC pickup..old blue Restored Vent Windows https://67-72chevytrucks.com/vboard/...d.php?t=766598 1955 GMC hydramatic build http://67-72chevytrucks.com/vboard/s...d.php?t=429417 |
03-13-2013, 09:59 PM | #31 |
Don't listen to these guys! The first thing you have to do is get your wife used to the idea that:
(1) Your garage will be tied up for the next few years. (2) She will need to purchase household cleaning products in volume. (3) Dinner will be served in the garage. (4) She must get used to telling the local power provider that "No, we are not running a grow-op. It's the welder and plasma cutter that are using all the electricity...........honest". BTW: You must get used to hearing her say "get away from me you pig, you smell like a dirty old truck".
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
03-14-2013, 08:39 AM | #32 |
03-14-2013, 08:41 AM | #33 | |
03-14-2013, 02:51 PM | #34 |
I don't know what all the other guys are talking about,the FIRST thing you gonna need is a saw,cuz there ain't no way you can jack that truck up high enought to get it off that tree(first pic).
03-14-2013, 02:52 PM | #35 |
03-14-2013, 03:25 PM | #36 | |
alabama1949chevy, cool story and glad you are keeping it in the family. Should be a good project. Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
03-15-2013, 10:17 AM | #37 | |
03-15-2013, 10:39 AM | #38 |
This is what the passenger side looked like when I found the truck! Yeah you can tell I was on a hunting trip...hence the rifle! HAHA
There were Vines growing up around it, the tree in the engine compartment... |
03-22-2013, 08:18 AM | #39 |
With a little bit of elbow grease I finally got the drivers side door open!
03-22-2013, 08:32 AM | #40 |
My advice would be to run away, as fast as you can, RUN!
03-22-2013, 08:50 AM | #41 |
HAHA! Although nobody has told me that yet on this site, you are not the first person to tell me that! I've never one time backed down from a fight but i have the feeling this is going to be the toughest fight I've ever been in! But I'm up for the challenge!
03-22-2013, 11:44 AM | #42 | |
i didn't write up a plan; the plan changed so much i would have been rewriting the plan 90% of the time. this also might explain why it took me 8 yrs to get truk on the road
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
03-26-2013, 08:59 AM | #43 |
This may be a stupid question but I'm gonna ask it anyway because if I don't I'll probably never know...
I plan on using an original 216 in my build, and I've been reading a lot that the top speed for these is around 45mph. Is there a way to modify the engine/tranny to increase the overall speed of the truck? Fire away! |
03-26-2013, 09:46 AM | #44 |
The engine isn't really the problem. Yes the 216 won't be able to safely rev really high but its more of the fact that you have low gearing all the way back. Your options would be to swap the trans and rear end to a set up with better gearing and then you'd have a open drive shaft. The easyest way if you want to keep the stock stuff is to get a ring and pinion kit from Patricks. The change in rear end gearing will boost your overall speed by about 10-15 mph i think. Stovebolt.com has gearing calculators (or all over the web) where you can put in your final transmission gearing (1:1 for you), your tire size, desired rpm, and rear end gearing (stock is 4.10, patrick's kit is 3.55) and they tell you the speed you'd be going.
With that said I have all the stock everything including the 216 and I can run 55-60 but my tires are slightly taller than stock.
My 1950 Chevy build |
03-26-2013, 10:00 AM | #45 | |
03-26-2013, 02:05 PM | #46 | |
04-02-2013, 06:55 PM | #47 |
Welcome to the forum. Good to see more AD's in Alabama. I got a 50 i am doing an s10 swap and v8. Got a 216 motor, trans and rolling chassis to go under that body if you decide to keep it stock. Im not gonna use any of it. I live toward Birmingham. Just let send me a pm if you are interested.
1954 Chevy 3100 5 window, bagged on s10 frame, 6.0 ls swap/4l80e Past build thread http://67-72chevytrucks.com/vboard/s...=531261&page=3 1949 3100 s10 swap 5.3. Instagram -@thejcates |
04-03-2013, 08:56 AM | #48 | |
04-03-2013, 09:58 AM | #49 |
frankenstien Fabrications
HAHA! Although nobody has told me that yet on this site, you are not the first person to tell me that! I've never one time backed down from a fight but i have the feeling this is going to be the toughest fight I've ever been in! But I'm up for the challenge !
now here's a a die hard fan of old sheet metal
frankenstein Fabrications |
04-03-2013, 10:51 AM | #50 |
id probly start by getting it out of that field and putting the bed, cab and front clip on stands so they can roll around individually. makes it easier for me to work on it especially with limited space
