#26 | |
GoatLube Experss
![]() Join Date: Oct 2009
Re: Is there a holy grail thread for shortening lwb to swb frame
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#27 | |
![]() Join Date: Feb 2013
#28 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Posted via Mobile Device |
#29 | |
#30 |
![]() Join Date: Jun 2010
Okay I have a few questions about shortening the frame. When I measure am I measuring off the back of the cab? The little crossmember that is there is throwing me a curveball. If I am suppose to measure off of that then it off the lip of the crossmember of the backside of it. (See pics). Just to see where the lines would be I measured off the back of the lip.
As far as cutting the back of the frame goes. Right now I have about 10.5" from the rear of frame to the first rear crossmember. From what I have read I have to move the crossmember before cutting 3-6" off the rear frame. The issue is that the cross member is pretty much even with the rear spring hanger. I don't feel that something is right. You can see in the photos where everything is located.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
#31 |
Pics of rear frame and crossmember.
#32 |
I laid a large carpenter's square up against the back of the cab and measured back 9 inches to find my cut line. Then, 14 inches beyond that to find my second cut line.
My truck being a 2wd, it has a different rear crossmember arrangement than yours. My crossmember was held into place by 6 factory rivets. Once I removed those rivets, there was a full set of factory holes located about 6 inches further forward. I just slid the crossmember forward and bolted it into those holes. ![]() ![]() ![]() ![]() |
#33 |
Have you put the short bed back on it yet. Just wondering if the mount holes for the bed all lined up. I will try the carpenters square and 9" back and compare my lines to yours and go from there. As far as the rear crossmember goes it looks like mine sets where yours does now. I don't think I will have to move it. Thanks.
What made you go with the 9" off the cab? Everything I have seen is 6" in order for the frame holes to line up went mounting the bed. Just curious.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie Last edited by rs74; 03-17-2013 at 09:04 AM. |
#34 |
I chose 9 inches because I read a well done thread on here where a fellow did it that way. I preferred it since that got my weld and splice area further away from the cab yet still enough room away from the spring hangers. I wanted an expanse of space that was easy to work in without having to pull the cab.
As far as the bed, yes I have it in place. Four of the bed mount holes lined right up and the rest needed drilling. I wound up doing it a different way though. I'm running a stepside bed and wanted a metal bed floor so I modified a long wide bed floor and cross members to go into my short stepside bed. ![]() Posted via Mobile Device |
#35 |
I think that when I cut my frame I am going to cut one side one way and the other side the opposite way. I don't know if it will make any difference but my thinking is that it won't have the same exact stress points. Maybe make it that much more solid.
#36 |
this is an awesome thread!!
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
#37 |
not a holy grail as its a sin to cut up a longbed. jesus was a carpenter.
#38 | |
i know this is off topic, but i am getting ready to do a frame swap, WHERE is the vin located on the frame? i have never been able to find it on any of my trucks in the past. I have found numbers but none of them coordinate with the numbers in the vin.? thanks in advance.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
#39 |
But Found Her 25yrs Later!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#40 |
saw this a while back and its straight from GM so i guess this is the real legit way? and imo having a sleeve seems a lot stronger than a zig zag weld with a fish eye plate. I am no expert though
#41 |
Found the full pdf
http://www.google.com/url?q=http://w...lDZS3LdKeKIubw
#42 |
This is how I was going to do it AND you can use the piece you cut out for the sleeve with a little modification. Then I found a frame on CL and it saved me a bunch of time. Here in FL they don't check the frame VIN. And as long as the frame is not stolen - Why would it even matter?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#43 | |
As for location, on my 74 it was right on top toward the front underhood area. They only check it here if it's coming from out of state.
#44 |
I'm a little late to the party here, but I will add my opinions and experience as well. I was sold on the "Z" cut while researching mine and at the last minute decided to do a simpler 45 degree cut. I read somewhere a post from a guy that worked for a company that built wreckers. He stated that the "Z" cut gave them the most problems with longevity. He had two frames come back with cracks coming off of the corners of the "Z". Not real big problems, but problems none the less. The 45 degree cut was a middle ground between the straight cut and the "Z". It gives you a little more weld surface. Feel free to check out my build. I documented my steps pretty well.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#45 | |
Happy to be here
![]() Join Date: Mar 2000
#46 | |
At the body shop.
" That didnt make it any newer " " Dont antique the equipment " |
