Old 04-21-2013, 08:04 AM   #26
64tantruck
64tantruck's Avatar
Re: 1961 Apache SB SBW build
Last night my wife and I were able to get the front end bolted in. Its rather difficult to find 7/16 grade 8 fine thread bolts. So we bought some course thread and locking washers along with some loctite. Im sure it isnt going anywhere. We still have to figure the locations of the shock mounts, tie rods etc... Then its on to figuring out the steering (we hope to add power steering). Anyway heres the latest pic.
The Korecs
Glenn Korec
Jamesville NY
64 C20 350ci Turbo 350 tranny 3.73 gear with air ride.
61 Apache10 (wife's truck) 327ci powerglide.
http://67-72chevytrucks.com/vboard/s...d.php?t=570100
64tantruck is offline   Reply With Quote
Old 04-29-2013, 12:22 PM   #27
64tantruck
64tantruck's Avatar
Update!
Rear brake lines replaced. New Wheel Cylinders, hardware and shoes. Drums will be painted body color. Then on to the the front. Once the front brakes are done we'll have a roller, onto the cab body work.
Glenn Korec
Jamesville NY
Old 04-29-2013, 06:41 PM   #28
Jmorales3181
Jmorales3181's Avatar
Looking good! Keep at it!
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 05-12-2013, 08:51 PM   #29
64tantruck
64tantruck's Avatar
Little more done.
We've gone as far as we can for now on the chassis. So we wheeled the cab out and got a lot done today. We removed the heater, master cylinder, and cleaned up the fire wall. Primed the firewall. Then started to replace the rigt cab corner. Here's a pic of Cyndy welding on the cab corner. Our first time welding, lets just say we need to learn alot.
Thats it for now G&C
Glenn Korec
Jamesville NY
Old 05-20-2013, 01:39 PM   #30
64tantruck
64tantruck's Avatar
Quick update were working on the cab. getting it ready to mount back to the chassis. Trying to free up some room in the garage. Here are some pics. Fire wall and interior painted. The floor has been completed, and we used spray on bedliner to seal it up.
G&C
Glenn Korec
Jamesville NY
Old 05-20-2013, 05:37 PM   #31
Jmorales3181
Nice work....you two are jamming out
Old 05-24-2013, 09:54 AM   #32
64tantruck
64tantruck's Avatar
Pretty much, each day we pick a station on Pandora, crank the tunes and go at it..
Of course, money and time is all it takes, when you have one, you dont have much of the other.
G&C
Glenn Korec
Jamesville NY
Old 05-24-2013, 10:15 AM   #33
Jmorales3181
Yeah I can relate to that. I don't have any money or very much time just making a dream come true
Old 06-15-2013, 06:21 PM   #34
64tantruck
64tantruck's Avatar
Been a while but got a lot done. Front rotors
On. Also we were able to set the cab on the
Frame. Still a lot to do, but were back to
Putting things back ON the truck
Glenn Korec
Jamesville NY
Old 06-15-2013, 11:50 PM   #35
62-One-Ton
62-One-Ton's Avatar
What did you do to get those small center hole wheels to fit on the big centered axle shaft on the rear?
Project Change of Plans: http://67-72chevytrucks.com/vboard/s...d.php?t=513135
'62 C10 SWB
'03 Express Van 5.3l Dead (parting out and using motor)
'99 Silverado 4.8l 5 speed 4wd
62-One-Ton is offline   Reply With Quote
Old 06-16-2013, 06:41 AM   #36
64tantruck
64tantruck's Avatar
We bought one inch spacers/adapters. The new
Wheels have a difference of a 1 inch offset.
We originally bought 4 but with the newer
Front end (73/87) we don't need any in the
Front.
Glenn
Glenn Korec
Jamesville NY
Old 06-16-2013, 10:49 AM   #37
64tantruck
64tantruck's Avatar
Chloe wants to know if we can take it for a ride.
Glenn Korec
Jamesville NY
Old 06-16-2013, 01:35 PM   #38
62-One-Ton
62-One-Ton's Avatar
Did the width end up narrower then stock still?
'62 C10 SWB
Old 06-16-2013, 01:51 PM   #39
64tantruck
64tantruck's Avatar
It was with in a quarter inch. The wheels rubbed.
With the one inch offset they were within 1/4 inch
Glenn
Glenn Korec
Jamesville NY
Old 06-16-2013, 01:59 PM   #40
62-One-Ton
62-One-Ton's Avatar
Narrower or wider? Sorry for all the questions I have a set of '05 17" silverado wheels for my '62. I was just thinking of machining down the cent of my rear shafts to fit the wheels.
'62 C10 SWB
Old 06-16-2013, 02:13 PM   #41
64tantruck
64tantruck's Avatar
Narrower these were 07. 16 inch wheels
Off a Tahoe or suburban. The axle center
Hole was too small. Not knowing at the time
We had an offset problem. We ordered the
Adapters. So one problem was solved by the
Other.
Glenn Korec
Jamesville NY
Old 06-16-2013, 02:15 PM   #42
62-One-Ton
62-One-Ton's Avatar
Sounds like it worked out well.
'62 C10 SWB
Old 06-16-2013, 04:32 PM   #43
64tantruck
64tantruck's Avatar
It did hope the info helps. i hace recieved so much info here. Nice to be able to share some.
Glenn Korec
Jamesville NY
Old 06-16-2013, 05:03 PM   #44
62-One-Ton
62-One-Ton's Avatar
Happen to have a pic of the spacers?
'62 C10 SWB
Old 06-16-2013, 05:19 PM   #45
64tantruck
64tantruck's Avatar
Here's the spacers. For them on ebay for
About $125 shipped for all four
Glenn Korec
Jamesville NY
Old 06-16-2013, 05:20 PM   #46
64tantruck
64tantruck's Avatar
Also note I'm running 235/70R16 tires and have
71 1/4 inches white wall to white wall
Glenn Korec
Jamesville NY
Old 06-16-2013, 05:28 PM   #47
62-One-Ton
62-One-Ton's Avatar
Nice. Thanks for the pics and info.
'62 C10 SWB
Old 08-26-2013, 07:48 AM   #48
64tantruck
64tantruck's Avatar
Its been a while but here are some updated photos of the progress. Put on a hold for about a month while we enjoyed some of the summer.
Glenn Korec
Jamesville NY
Old 09-09-2013, 08:04 AM   #49
64tantruck
64tantruck's Avatar
A few more pics fo the truck. Were making progress.
Glenn Korec
Jamesville NY
Old 09-09-2013, 09:29 AM   #50
Ta2Don
Ta2Don's Avatar
Nice!!! Diggin' the color!!!!!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
