Old 03-14-2013, 05:45 PM   #26
RHGuyettejr
RHGuyettejr's Avatar
Re: Engine Troubles...
Originally Posted by trevrolet65 View Post
I 'd run a compression check on the cylinders missing
Yeah, Im going to pick up a compression gauge tomorrow night after work (i should own one anyway with all the other vehicles I work on) and also borrow a dwell meter form a friend. Ill run the compression check and see what happens.
Just a question, having never done this on an older engine, will the continued cranking flood the carb? and is there a way to prevent that?
RHGuyettejr is offline   Reply With Quote
Old 03-14-2013, 06:53 PM   #27
trevrolet65
Leave the choke off and don't hit the gas peddle or throttle linkage. If she floods, she'll just crank over faster. A trick I use to start with a low battery. I've had the cylinders bypass due to failed head gaskets. The bottem end sounded good from what I could tell from the vid. If the compression tests bad, I guess pull the plug beside and see if air is swooshing back and fourth, you can tell. Then its pull the heads time, sorry.
trevrolet65 is offline   Reply With Quote
Old 03-15-2013, 06:57 PM   #28
RHGuyettejr
Well I did the compression test, and the results are in
1 = 0psi
2=149psi
3=149psi
4=130psi
5=0psi
6=148psi
7=5psi
8=149psi
Looks like I need to pull the heads
Old 03-15-2013, 07:41 PM   #29
Lattimer
Lattimer's Avatar
1 = 0psi
2=149psi
3=149psi
4=130psi
5=0psi
6=148psi
7=5psi
8=149psi
That sucks.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-15-2013, 08:03 PM   #30
trevrolet65
pull the valve cover on that (the left) crank it over and see if the lifters are rocking up and down, maybe flat cam.
Old 03-15-2013, 08:04 PM   #31
trevrolet65
or the lifters collapsed or not adjusted the rockers.
Old 03-15-2013, 08:05 PM   #32
trevrolet65
or broke studs, may have pulled loose
